355ci Help.
Old Mar 21, 2005 | 09:15 PM
kukri's Avatar
Default 355ci Help.
I dont actually have a camaro, its an 90 rx7, with everytihing camaro in it.
355ci out of '88, 6 spd out of '02 and POSI. the motor doens't really have anythign 88 in it, of course except the block. Car is pretty quick.
I have a couple of questions.
first of all what is my motor? 355ci chevy carburetor..would that be lt4??
Also Who would make custom headers for that kind of motor.. I could probably find out better if i knew what motor it is. Thing is..had to get small headers, because steering column in the way of bigger headers, so im trying to find custom headers that would go closer to the motor and into pipe..car is already pretty quick but those headers i got on there not moving air like bigger ones would. Would probably release up to 40 hp just from them..
Q3: Got 2 straight 3inch pipes coming right out of headers, isn't that the most hp..i couldn't imagine muffler giving more hp...(dumb question)
I'm sorry for many questions I'm just trying to start learning this stuff and workign on the car myself.
If this is the wrong section of the forums let me know.
Thanks.
Old Mar 22, 2005 | 10:58 AM
mikes98z's Avatar
Let me see if I can help........
You will need the casting number off of the block......check on the top of the block, right behind the cylinder head....you can go to mortec.com for a huge list of casting numbers and they can give you a great source of info on the motor....the later generation lt1/lt4 motors didnt come out until 93 I believe. I could be wrong on this but I would check.
As far as headers, see if there is a conversion kit out there...if not, you may have to have a set made...Do a google search and see what you come up with.
As far as the stright pipes, you may gain some HP but lose some torque down low.....no big deal since its a light car. Today's muffler technology is great and will keep Johnny Law from giving you a ticket.
Good luck and keep us updated.
Mike
Old Mar 22, 2005 | 09:03 PM
kukri's Avatar
That's so true.. It doesn't like crusing in high gear/low rpms or starting off low rpms. (800-1500rpms), matter of fact i think car hates low rpms and idling.
I appreciate the info. Also am getting help on the headers from the guy i bought the car from, he seems to know his stuff. He said he knows a guy that makes headers JUST for that car, so he must make 1. (jk)
actually there is about 3000 rx7s of all gens world wide with v8s in them.
Old Mar 23, 2005 | 07:55 AM
PredatorZ's Avatar
I agree with mike, you need to find the casting numbers. The only 350 from an '88 Camaro would be the L98 TPI. Obviously it was modified, being bored out .030 over (to get you the 355ci) and the TPI system was scrapped for a carb setup, but that is only if the motor in the camaro was original to begin with... so check the casting numbers to find out more.
Regarding the size of your exhaust, the bigger you go the worse your torque will be. You need to maintain some backpressure on the exhaust for everything to work most efficiently, and with a 355 I don't think you are gaining enough horsepower to justify the loss of torque. For what its worth, thats my opinion.
Old Mar 23, 2005 | 10:15 AM
kukri's Avatar
the motor was actually original 355.. and i was wrong its out of 87 chevy. - might've not been out of camaro. Im gonna find the casting numbers.
Old Mar 23, 2005 | 11:32 AM
mikes98z's Avatar
It will be intresting to see the casting numbers because I have never heard of an ORIGINAL 355...please let us know, I know I am very curious.
Regards,
Mike
Old Mar 23, 2005 | 12:50 PM
PredatorZ's Avatar
Regards,
Mike
Me too!
Old Mar 23, 2005 | 03:04 PM
kukri's Avatar
You're right its not no original 355. If its bored over does that mean its not as stable when it comes to HUGE amounts of power? I'm sorry im so new. I wonder how much power it would hold. Ill get info on the compression rat., pistons, heads
Old Mar 24, 2005 | 07:44 AM
PredatorZ's Avatar
Not at all, a .030 overbore is well within the allowable range for a stock 350 block. You can actually go bigger if you want, or even leave the bore as is, and stroke it out to 383! Then you can really start pulling some power out of that block. When you find out more info you can better predict the power of the motor, but without a dyno it would all be a "best guess". You can assume conservatively that a more or less stock "355" is somewhere in the mid to upper 200's... but again it is just a guess without knowing what was really done to the motor and a dyno for real data analysis.
Old Mar 24, 2005 | 09:52 AM
kukri's Avatar
Does anyone know what could it be. My car yesterday started being REDICULOUSLY LOUD. It's aleady loud as hell, but i went to a gas station filled up with gas and next time i cranked it it was LOOOOOUD. During cruising its the same, but during revving and acceleration it gets rediculous. I'm getting decent oil pressure and enough oil in there, so its not like oil pump is broke. It's a little dry sound, but not really like it has no oil sound.. Any idea what it could be?
Old Mar 24, 2005 | 12:33 PM
PredatorZ's Avatar
Exhaust leak.
Old Mar 24, 2005 | 03:57 PM
kukri's Avatar
I hope that's what that is nothing more. i see some exausts comeing out of under there car... It's actually loud from the motor not the exhaust pipes, someone said i might have manifold/header leak and they're old and rusty with rusted bolts.. Wow it would be a pain to replace those
Would man. leak affect power? i would think it would due to loss in compression..
Life hates me. j/k
Old Mar 24, 2005 | 09:47 PM
kukri's Avatar
the motor is L98 btw.
Old Mar 25, 2005 | 10:03 AM
mikes98z's Avatar
L98 is a good motor to start with. It came from the factory with 9.3:1 CR, 230 hp/330ft.lbs withthe TPI in the camaro, but since yours has been rebuilt, I am not sure. I would guess you have an exhaust gasket leak at the head. Place some WD on the bolts when the headers are cool... Just be careful not to break a bolt.
Good luck
Old Mar 26, 2005 | 07:08 AM
kukri's Avatar
I replced the gaskets between heders/block, and then saw that its the gasket that connects headers to exhaust pipe.... its was missing 2 bolts..other one has one lose..for some reason bolts geting lose, i guess because of vibration, I'm gonna put some thread lockers. pain in the butt to get there, i have to lift the car somewhere.. motor is at 10.25:1 cr, also
flat top keith black pistons
Scat 6" rods
Scat crank
Trick Flow 23 degree heads
Comp Cams XE284 cam and lifters
Summit 'Black' aluminum roller rockers
Miloden Diamond Stripper windage tray
It's got turbo rx7 rear end posi and 4:10 gears
Old Mar 26, 2005 | 09:01 PM
kukri's Avatar
k i fixed the leak, car seems so quiet now.. I have a feeling i had several leaks.
it sux to get used to car when it dont seem fast no more
Old Mar 27, 2005 | 01:46 PM
kukri's Avatar
I've been told that since mycar redlines at 7K rpms..it dont have "l98" tpi which means it aint really l98
Old Mar 27, 2005 | 02:41 PM
badjuju342's Avatar
Deranged Rat Fink
The questions you are asking would be better suited for the "Conversions & Hybrids" forum. Also , without a casting # from the block ,it's going to be difficult to tell exactly what you do have. There are a few RX7/SBC swaps in the forum I just mentioned. I would have told this earlier but I've only been a moderator since ....um...... LAST NIGHT!
Old Mar 27, 2005 | 07:29 PM
kukri's Avatar
lol thats coo congrats.. i wasnt really asking question.. it was originally l98 but nomore
Old Mar 28, 2005 | 09:00 AM
Scooter70's Avatar
The L98 block wasn't really that different from the older smallblocks. The only real big thing that made in an L98 is the injection system, which you no longer have. That injection system was the reason for the low redline. It just stopped making power after about 5200rpm. Now that you've got the carb, the sky's the limit.
