Block hugger headers
Old Mar 23, 2005 | 08:42 AM
Stu Cool's Avatar
Default Block hugger headers
Has anyone tried a set for their swap? I see several companies offer them. Experience? Recommendations? I am looking at this more from a "will it fit" perspective, not so much "will it perform."
thanks
Pat
Old Mar 24, 2005 | 04:23 AM
67pete's Avatar
I tried the Heddman block huggers and they fit ok...but the workmanship left a lot to be desired. Went and modified they originals to keep that factory look.
Old Mar 24, 2005 | 08:23 AM
Stu Cool's Avatar
Thanks Pete, What mods did you make to the originals? I am concerned about that huge flange at the outlet, I think it will hit my steering box.
Pat
Old Mar 24, 2005 | 09:30 AM
67pete's Avatar
With my car, the stock passenger side ran right into the subframe connector at the fire wall. Using the '99 T/A (same as Camaro) manifold, which is a double walled unit, I brought the flange down between the last two cylinders which gave me clearance from the A-arms and the subframe connector.I had even tried the Corvette manifolds, but modifying the stock unit even with the double wall of stainless steel (vs cast iron) looked the better route. Hopefully my welding will hold up!
Old Mar 24, 2005 | 07:52 PM
GTS346's Avatar
Pete do u have a pic of the originals?
Old Mar 25, 2005 | 10:34 AM
81LS1Camaro's Avatar
and the modified ones
Old Mar 28, 2005 | 04:36 AM
67pete's Avatar
Will try and get pictures when I get it out of the car........
Old Mar 28, 2005 | 03:50 PM
GTS346's Avatar
Are we talking regular SBC block huggers or LS1 block huggers?
Old Mar 28, 2005 | 05:03 PM
Stu Cool's Avatar
Block Huggers for the LS1 in general applications like a street rod, or... a Studebaker
thanks for any info you can provide
Pat
Old Mar 29, 2005 | 03:48 AM
67pete's Avatar
According to the "experts" ,including GM, the small block & LS1 are one and the same.............but for those of us who've tried them both, we know different.
Old Mar 29, 2005 | 05:02 PM
Oscar Will's Avatar
Default Block huggers?
I tried the Covette manifolds, they tuck in pretty close and clear everything on my 1935 Ford
Old Mar 29, 2005 | 07:53 PM
Stu Cool's Avatar
Thanks, I have a set of the Corvette manifolds and will try them, but I think because they come down in the middle they will hit my cross member. I have just been studying the manifolds on my 5.3 Silverado and they look like they would dump far enough to the rear, without that huge flange that the F Body manifolds have, that they would clear my steering box. Truck manifolds might be the answer. Nice to know I have options.
Pat
Old Mar 30, 2005 | 04:08 AM
67pete's Avatar
There might be a difference between the regular Corvette manifolds and the Z06 manifolds, as the Z06 manifolds I have dump just rear of the center, which is further back than the block huggers do.
Old Mar 30, 2005 | 10:04 AM
red90cobra's Avatar
Talking
I was like what that on the intake till I looked again and saw it was your intake
Old Mar 30, 2005 | 03:06 PM
GTS346's Avatar
Oscar what are those pipes made of, mild steel and you just coated them?
What size primary and what size collector do they have?
Also do you have a front shot of the engine and that side header, I just want to see the angle they come out on.
Old Mar 30, 2005 | 07:08 PM
Oscar Will's Avatar
That was the only place I could find to put an airbox with filter....on top of the intake. It works well, very little intake noise. Those are stock 1997 Corvette "stamped steel" manifolds, I'd say the primaries are about 1 3/4" maybe, the collector is 2 1/2". I ran 2 1/2" all the way with a Spintech x-pipe and 2-in...2-out Spintech muffler. The headers are ceramic coated.
