LS1 Swap FAQs
EDIT
Found it in one place, but the file size is too large for one document (forum rule). I have copied it as PCM Connector C1 and C2 to Microsoft Word Documents & attached them. It will not copy & paste here due to graphics.
Didn't see a listing for a body control unit, too many things in there.
For the clutch switch:
Clutch Pedal Position (CPP) Switch
Connector Part Information
S42
2-Way Female (WH)
Pin
Wire Color
Circuit No.
Function
A
GY/BU
275
Neutral Safety Switch Signal
B
GY
434
Park Neutral Position Switch Park Signal
I'm picking one up tomorrow and will edit this post with the GM part number.
PART NUMBER: 14104460
PN 0178 for the 1 3/4" LS1 flange, 1 3/4" its $24.95 for the pair.
http://www.schoenfeldheaders.com/
Misc.
12369966 SS logo (Silver)
12369965 SS logo (Red)
25121942 Fuel filter
The top of the radiator in my sandrail is higher than the tube. I use a vacuum pump to suck all the air out of the head.
This fitting Will install in the place of the stock style fitting and uses the stock roll pin. This can be used in almost all late model gm clutch masters and slaves. You can remove the stock f-body fitting from the throw out bearing or from the slave and install this..... these are kind of expensive but being able to convert the stock slave to a -4 style fitting is well worth the cost.
I snapped a few pics and can get you guys some part numbers If you want.
