Any T56 Fox LS1 conversions yet?
Also, any issues with a 3.73 and the T56 running a 245/45/17 or maybe a 275/40/17 in a Fox? I know the F-bods don't like the 3.73/T56 much, but the Fox is a LOT lighter. I already have the 3.73 8.8, but I can always go 3.55 if need be.
What about the switch to hydraulic clutch?
There is no room on the firewall in front of the Mustang clutch pedal because the frame comes in right there. The LS1 hydraulic master cylinder fits perfectly throught the firewall where the clutch cable should go, but I can't figure out a way to get the cylinder to engage.
Since Mustangs use a quadrant and a cable that pulls, and the LS1 cars use a hydraulic cylinder that pushes, they work opposite from each other and won't work.
You said you kept the Hydra-boost right? I just sold one, and decided to go conventional MC/booster.
That sounds like a hell of a lot of work. Especially since there will still be no room on the firewall for the master cylinder since the frame is there.
Mustangs use a quadrant to pull the cable. The quadrant is on a shaft that is to the right of the clutch pedal (above the gas pedal). That is where the hole in the firewall is for the clutch cable. Right now this is where I planned on mounting the master cylinder since it fits so well, but I need to figure out someway to convert the quadrant from a pull type to a push type and push the master cylinder in.
