Unidentified harness connectors question
Hi, I am swapping an LS1 into my RX-7, and I figure i am going to have to bite the bullet and purchase a wiring diagram for the LS1 so I know where I will need switched 12V supplies etc. Does the stock set-up use a relay to power the LS1 PCM? I attached some pictures of the connectors I am not sure about. Can anyone help me to identify them?
That's what she said...
1 2 and 3 run over the passenger side fender well and run the lights, and horns and **** (i think)
number 4 looks like the A/C high pressure switch connector
that number 5 is a vacuum line that opens the A/C flapper (i'm pretty sure)
6 and 7 look like some interior plugs due to the fact that they arent sporting any kind of weathertight connectors. i'm going by the fact that i've never seen them before and can be found under the hood more than inside the car lol
Wow, are you sure? So I guess that means I don't need a custom switched 12 volts to anything? Those are the only connectors on the harness that aren't connected to anything. If so, thats great, I guess I can just plug the harness into the battery and start her up. Oh, and thanks for the help ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Awesome, thank you so much. This helps me alot.
~Bob
~Bob
Originally Posted by MrDude_1
see the pics for info... heres the linked post:
https://ls1tech.com/forums/showpost....06&postcount=4
