About an ls1 in a 1994 v6...
The carrier is what the ring gear (from a ring & pinion set) bolts to, and is what turns the axles.
Here is an Auburn style limited slip carrier sitting inside the axle housing with ring gear bolted to it:
I did a search for 1994 Camaro, Axle Assembly Rear (w/ Housing) in Kentucky and found a handfull of axles for $300 or less. Just make sure you specify limited slip and make sure you pull the cover off and verify it is a limited slip before you install it.
One more thing is that you will more than likely get the rear disk brakes with the LT1 rearend which is good.
As far as a rear-end or rear axle, thats the same thing, just different terms. A "carrier" swap would convert the non-limited slip into a limited slip, providing you swapped in a limited slip carrier. I felt that entire axle replacement would be better for somebody who might not be able to swap out a carrier.
As far as NEEDING a new rear, absolutely not, you'll just be doing the "one wheel peel" until you upgrade.
Spool = both wheels spin 1:1 "very hard to handle on the street
Limited = each wheels spins at different speeds "but the wheel that has less traction spins faster...
so not all v6 have open diffs
