'98 LS1 IAT part #
Old Jul 21, 2005 | 03:46 PM
GTA91's Avatar
Default '98 LS1 IAT part #
Anyone have this?? And how much? I can't find mine....
Old Jul 21, 2005 | 09:50 PM
MM98's Avatar
GM part#12160244, they run about $15 from the dealer... And 98-02 sensors are the same.
-Mike
Old Jul 21, 2005 | 11:29 PM
jimmyp's Avatar
those sensors are on alot of different vehicles...if your junkyard searching
Old Jul 24, 2005 | 10:12 PM
StngKlr's Avatar
The IAT sensor will be on the airbox somewhere, if thats what you mean by you cant find yours. The one from my stock 88 V6 airbox works fine with the LS1 pcm, even the connector from the LS1 harness will plug right in to the older sensor.
Old Jul 24, 2005 | 10:15 PM
GTA91's Avatar
Thanks guys! I don't have the one from the LS1 car and I sold my old TPI motor complete so I guess I'll order one or get it fromt he junkyard.
Thanks!
*Dumb question, but I'll ask it anyways... it doesn't matter where I put it does it?? Before or after the MAF, etc, etc....
Old Jul 26, 2005 | 09:39 PM
StngKlr's Avatar
I would put it in somewhere between the air filter and the maf. Should be fine.
Old Jul 27, 2005 | 08:54 AM
MrDude_1's Avatar
anywhere in the intake air stream is fine. theres sometimes a good bit of diff between air temp in the air intake, and air temp just outside of it.
Old Jul 27, 2005 | 10:02 AM
digitalsolo's Avatar
Mine is after the MAF, works fine too.
FWIW, I know the 97+ Grand Prix/Regal use the same sensor too.
Old Jul 27, 2005 | 10:09 AM
jagwrjack's Avatar
Also, the Helms manual show the wrong part # for the IAT.
MM98 gave you the correct one.
Still regret buying those Helms manuals.
Old Aug 5, 2005 | 08:16 PM
sunsetta's Avatar
If you want a good source for part#'s, go on Ebay and buy you a CD ROM for $3.00. It covers all years from 93-02. It consists of about 2,400 microfiche. I use mine all time, even help people on LS1TECH when they need part#,s. Best $3.00 I ever spent.
Old Aug 8, 2005 | 12:10 AM
G-Body's Avatar
sawzall wielding director
CD sounds cool, I`ll have to check that out but, gmpartsdirect is another way to get most of the part numbers. unless you need bolts or some gaskets
https://ls1tech.com/forums/conversions-swaps/336750-iat-sensor-part-number.html
