Ls1 Radiator Into Third Gen Trans Am
I Want To Use The Radiator Of The 4th Gen And Put It In The 3rd Gen Trans Am. Direct Fit? Any Modifications That Will Need To Be Done? Will The Original Air Cleaner Fit?
help
i fit my 4th gen rad by standing it strait up and using an lt1 shroud with ls1 fans.
02 ss rad
02 ss fans
97 shroud.
lil modifying (time consuming) to the shroud and everything fit with lil effort.
it makes the swap look that much cooler.
it almost doesnt clear the steering box. depending on the car, you may have to cut the fan blade cover a bit, but no mechanical differences.
in my setup, the 4th gen fans worked WAYYYY better than my stock fans (with a spohn wonderbar) stock fans and a spohn bar was a pita to remove them.
good luck!
02 ss rad
02 ss fans
97 shroud.
good luck!
Thnx guy's! Hey TJ your picture help me much! I will look into a shroud of a 97 Lt1 trans-am. I notice the radiator cap sticks up a bit, im sure the hood closes fine right? My next question is...How did you go about for the aircleaner? along with the mass air flow sensor? any pictures? Just finished today installing my 4th gen tank into my 3rd gen. Went in with no problem! only thing I noticed was the fuel neck sticks out to much about 3 inches and need to trim it so the fuel door will close all the way. I bought some 4th gen fuel lines from ebay and on there way! Project going smooth, thnx to u guys. ahhh one more thing.. the vapor canister were is it located? is it the one that mounts on top of the fuel tank?
Reiko,
links to my ls2 pictures
http://img228.imageshack.us/my.php?i...ture0643lr.jpg
PS. did u install the ls1 a/c condensor as well? or kept the 3 gen?
Reiko,
The vapor canister on a fourth gen is in the drivers side rear wheel well. If your 3rd gen had a v8 it will be located under the hood on the passenger side front corner v6's had it on the drivers side. one line to the tank the other to the canister purge solenoid on the intake.
Reiko,
Reiko,
