Lt1 and Ls1 kmember
Old Aug 21, 2005 | 08:25 PM
joking511's Avatar
Default Lt1 and Ls1 kmember
Whats the difference between a ls1 and lt1 kmember?
The reason I ask is I'm putting a Ls1 in a 94 camaro . The Ls1 kmember is damaged from the wreck the donor car was in . I have a Lt1 kmember just sitting there and If I could just make some small mod. to it to make it work that's what I'll do . I already have the Ls1 in the car with the Ls1 kmember .But when I looked at the right side brake rotor it was up too far forward and the wheel wouldn't even go on. It looks like the A arm and kmember are damaged .
Thanks for any help .
Old Aug 22, 2005 | 09:16 AM
joking511's Avatar
Anyone ????????? ^^^^^^^^^^^^^^^^^^^^
Old Aug 23, 2005 | 01:31 PM
joking511's Avatar
anybody ????????????????????????????
Old Aug 23, 2005 | 09:26 PM
Despicable's Avatar
I'm interested too?? I too have a LT1 F body and am in the process of researching to do a LS1 switch. I have both K Members and want to know if I can use the LS1 K member.
Old Aug 23, 2005 | 11:36 PM
Brent@LPE's Avatar
I have both K-members in stock @work from BMR they look identical exkept the motor mounts (FRAME motor mounts should be bolt on in both apps.)I can verify tomorrow
P.S. also have plenty of stock LS-1 K-members alyig around
Cheers...Brent@exoticperformanceplus.com
Old Aug 24, 2005 | 10:28 AM
JasonShort's Avatar
Moderator
Tunafish is correct. The only difference is in the motor mounts. 3-hole for LT1, 4-hole for LS1.
Jason
Old Aug 24, 2005 | 01:05 PM
joking511's Avatar
I going to get an ls1 K-member anyway . But for those who would like to know , will the ls1 mounts line up with the 3 holes in the lt1 k-member ?
Old Aug 24, 2005 | 03:34 PM
BuffJoeyD's Avatar
So are you guys saying that if you have an LT1 you can just put on LS1 mounts to the LT1 K memeber? Im am trying to find out if something like this is possible for a 3rd gen. =) Gonna start searching now
Old Aug 24, 2005 | 07:54 PM
jswhite's Avatar
You can't bolt the the LS1 pedestals to the LT1 k-frame.
Old Aug 24, 2005 | 08:06 PM
CONVERTED's Avatar
who sell the crossmembers and k members?
Old Aug 24, 2005 | 08:52 PM
joking511's Avatar
There are lots of aftermarket ones . You can check your boneyards for a stock on . I got one from Billy Graham camaro and firebird salvage .
Old Aug 24, 2005 | 09:31 PM
joking511's Avatar
Thanks Thats is what I was wanting to know .
Old Aug 25, 2005 | 06:02 PM
Brent@LPE's Avatar
try BMR for good aftermarket K-member
