wiring harness mod how to?
Old Sep 8, 2005 | 02:20 AM
yodawagon's Avatar
Default wiring harness mod how to?
maybe this is wishful thinking, but is there a site that shows you what exactly to delete from your wiring harness? i know speartech can do it, but im hoping to save some money. i figure ill have the pcm reprogramed by them, but id be willing to try modding it myself if i had a referrence site and a how to for my dense ***.
maybe ill try to make sense of all the info on this site, and take lots of pictures, and make my own site.
Old Sep 8, 2005 | 02:53 AM
yodawagon's Avatar
maybe just a detailed picture of a reworked harness. in theory couldnt i just remove the unwanted stuff from the pcm plug?
Old Sep 8, 2005 | 05:17 AM
5.3 racer's Avatar
that's exactly what you do... eliminate waht you don't need out of the harness and pcm plugs. it's very time consuming but it won't cost you a penny. go to alldatadiy.com and get a subscription to the vehicle that your harness and pcm are coming from to find out what each wire is for. i knew nothing about fi and ls1's and it was a big help.
Old Sep 8, 2005 | 01:15 PM
yodawagon's Avatar
ill try that. im sure speartech is a awsome company, i just cant justify the money right now.
Old Sep 8, 2005 | 01:22 PM
NOSjohn's Avatar
Restricted User
We just put this up yesterday, courtesy of DV:
www.ls7power.com/diagrams
You will find the files are named accordingly. I hope that helps and try to get those photos up once you splice/cut your harness. It would be great to try and help some people who want to DIY and save some money.
Old Sep 8, 2005 | 02:53 PM
shackattack37's Avatar
he did my harness i it cheap and a good job if you got the stock harness he rewire it for 200.00 www.wait4meperformance.com
Old Sep 8, 2005 | 08:45 PM
yodawagon's Avatar
think im just going to have to go on all data and get the wiring diagram. what im hoping to find is a wiring diagram of just the wiring harness.well labeled. but maybe thats hard to come by.
Old Sep 8, 2005 | 09:37 PM
www.wait4meperformance.com label all the wires plug @ play in one hour
Old Sep 8, 2005 | 09:43 PM
Gen3Benz's Avatar
I modded a factory underhood harness
kept connectors 100/101/105 to plug into the factory engine/trans harness
https://ls1tech.com/forums/conversions-swaps/99135-finished-my-underhood-wiring-harness.html
then I removed all the junk from the engine harness
egr/air/evap/fuel tank pressure
Old Sep 9, 2005 | 01:43 PM
yodawagon's Avatar
wait4meperformance.com charges 300 for your harness to be reworked, and a computer programing. thats 450 less then speartech. anyone used them? how was the work? was it a true plug and play?
Old Sep 9, 2005 | 07:43 PM
6.0 mcss's Avatar
Try Dana at Lt1350wiring.com he is good and does it for cheap got my harness back in one week!
Old Sep 9, 2005 | 10:06 PM
G-Body's Avatar
sawzall wielding director
I thought that it was only 750 from speartech if you had a complete harness made, thought it was less than 500 to have a harness reworked. I did my own harness, but I did have wait4meperformance do my computer tune. My motor started right up, and I have not had any check engine lights or any other problems. I did have a check engine light when I first tried to drive it, but that was all trans codes, my fault I had a bad relay . I am happy with the tune and with the other help he gave me.
Old Sep 10, 2005 | 02:49 AM
yodawagon's Avatar
speartech charges 750 for a program and wire harness rework. wait4meperformance charges 300 for it.with that 450 saved i could buy alot of other needed parts.
