ANY carbed ls1s, wiring ???s
Need to find out how to wire up the stock 5.3 alternator...
Anyone done the swap to a carbed setup, and have to wire up the alt?
TIA
TIA
Originally Posted by 89lx-ls1
I am going to run it but i am using my mustang alt. for mine
Which accersories are you using?
TIA
TIA
Originally Posted by LS1S10
I was starting to think about the same thing, i just recently changed from going with the stock FI to using a carb. I've got a custom harness to run the FI, but thats not going to help me now. I was going to give Jared at currentperformance.com a call, he made the harness for me, and try to get him to either just make up a small harness for the starter and alternator....or just tell me about that one freakin brown wire its got going to it, and what the heck it does. Im using the vette alternator, don't think it would be any different from the rest of them except for the mounting points. All mine has going to it is the power output and one brown wire in the 4 pin plug.
Thanks
I guess I try to hunt down a wiring diagram, figure out which connector goes where....
Hmmm
Thanks
Thanks
Luckily on my 96 S10 the resistor for the excitor wire was pre-wired in the dash...so all i gotta do is tap into the firewall pin-out and im set. I can find out which particular pin-out on the alternator is the excitor wire tomorrow if someone needs specifics.
Originally Posted by GTA91
So would this be the single red wire (20 gage or so) on the '98 LS1 alternators?? Just a 470 ohm resistor in line with a switched 12v??? I'm having issues with mine... just got it running and it won't charge.
thanks!
thanks!
BTW i know this is about a month old, but my internet crapped out on me and im just now catching up on posts.
Actually it is the B pin and if you are looking at the alternater from the rear with the pins facing up it reads left to right. I just hooked mine up 3 days ago and it charges at 14 volts. Without the wire it read 12.5 volts which was the battery voltage. And no, you are not the only one running a carb on their LS1...so far I love it.
