will epoxy survive inside a fuel tank.
If youre talking about a rubber hose, get taht hose out of there and do it right.
since I can't weld steel to aluminium do you think I could sauder this connection
And even if you could, galvanic corrosion would be a nightmare. The steel would rust, extremely quickly.
Basically, it boils down to you need aluminum fittings, even if you have to make your own.
Some side questions:
What alloy aluminum did you use? Because there are several that are ok for gas tanks (like 5052) but some that aren't so good.
Do you plan on running any alcohol in this tank?
What kind of finish (if any)?
Have you thought about having the whole tank hard anodized?
'JustDreamin'
since gasoline has alcohol in it which kind of alcohol were you refering to.
Just pump gas Methonal/alcohol unless the locals start selling a mixture of "ethonal/alcohol".
The steel would be caused to rust faster and the Aluminium would last longer due to it robbing the steel I was told you needed water in the equation for this to happen.
Just found out 99 percent of epoxies are fuel proof.
No finish planned yet.
www.geocities.com/ls1chevy2
The current idea is to weld a 1/2" thick 1" by 1" piece of Alum to the top side of the tank drill a 3/8 hole through it then push the 3/8" tubing through and epoxy the outside. The epoxy may never even get a drop of gas on it since it will be on the top of the tank and be such a tight fit,
I wasn't going to just epoxy it to the 1/8 " sheet at the bottom the first bump it would probably come loose.
You won't be able to see the epoxy because of the tight fit
Question about alcohol was directed towards high percentages (more than the 10% they use in currently in winter blends and such). Don't really want to be in the "wonderful world of corrosion", do we....
Just trying to think outside the box, but is there a bulkhead type compression tube fitting that you could use. You're looking to have the tube come from the pump up to the outside world without having a seam / joint, correct?
Personally, I'm with the rest of these guys, epoxy on the fuel tank makes me a little nervous. Nevermind the fact that most fuel tanks these days are plastic and all, just makes me a little leary.... But hey, its your vehicle.... And your wienie roast if it doesn't go right. I hope it goes right!
'JustDreamin'
where is this tank being located?
