Oil Level sensor plug
Old 11-07-2005, 08:31 PM
John McGraw's Avatar
Default Oil Level sensor plug
Does anyone know of a plug that can be used to plug off the hole for the oil level switch on a LS1 pan? I put a F body pan on a LS2, and it did not come with a switch, and I can't see buying one since the LS2 does not use the switch and there is no connection for it to the PCM.
Regards, John McGraw
Old 11-07-2005, 09:10 PM
ls1_chevelle's Avatar
Its a big focker, but if you have a John Deere dealership near you.... Give them a shot!
-Matt
Old 11-07-2005, 10:14 PM
01PewterWS6's Avatar
That or hit up the plumbing section in the hardware store(REAL hardware store, not the BS Lowes/Home Depot bastards that dont have jack for real supplies anymore)
Old 11-08-2005, 01:37 AM
81LS1Camaro's Avatar
or just leave the stupid thing in
Old 11-08-2005, 07:01 AM
I would leave the switch on if it had one. I am just trying to avoid buying one if I don't have to. I am guessing that it is a metric thread which will make it real hard to find. I would also presume that it is a straight thread and not a pipe thread since the original switch installs with an O-ring.
Old 11-09-2005, 02:18 AM
GTS346's Avatar
I found a bolt at local nut n bolt shop but the thing was 3" long had to cut it down but they charge by the length and size so it was a $10 bolt.
Your best off getting it welded up if you a modifying your pan as the bolt will leak without thread tape and a fibre washer.
Old 11-09-2005, 10:01 AM
LS1GMCTruck's Avatar
Thumbs up There are two great sources...
for plugs like this. O-ring or not. The first is Aero-Quip. Get a catalog or go to your local Aero-Quip parts house. Actually, they were bought out by Eaton Corp., so they are now called Eaton-AeroQuip. They are in the catalog. Second is McMasters-Carr (McMaster.com) . Get their catalog. You won't believe how extensive it is. Gar
Old 11-09-2005, 11:18 AM
joking511's Avatar
Post in the parts wanted section . I sure someone has an extra one you could get cheap . It would be better than a oil leak.
Old 11-10-2005, 12:22 PM
crewchef's Avatar
Anyone ever find a plug for this and/or know what the size is.
Old 11-10-2005, 06:58 PM
Check over at the LS2 and LS7 section. I asked over there as well and a gentelman named John Lawson found a source locally for them and picked me up one as well. He can tell you where he got them. I posted a couple of links there as well. He indicted it was a 20mm X 1.5 thread. I did not find one in either the Areoquip or Mcmaster-Carr catalog.
John McGraw
Old 11-11-2005, 10:35 AM
MrDude_1's Avatar
thank you for going out of your way to come back here and post the thread size.
Old 11-11-2005, 02:17 PM
crewchef's Avatar
FYI, I found one at Advance today. It was on the rack with oil drain plugs and was only $1.98.
Old 11-11-2005, 08:56 PM
majefff's Avatar
Default oil plug
search umi racing phoenix arizona, they have a crome plug with oring seal, spendy part, i think i paid 29 dollars for mine
Old 11-16-2011, 09:01 PM
tomy2tone01's Avatar
Default Sorry to bring back an old post
Here's what I used NAPA part 704-1946 $2.99
Old 11-16-2011, 09:39 PM
LSCustoms's Avatar
yeh its real simple. 20mm x 1.5, at any auto parts store, should be a couple of bucks and should have a gasket with it.. just bought on the other day...
Old 11-16-2011, 10:34 PM
Tongboy's Avatar
speedway sells a plug with various internal threads for oil temp and other gauge senders
Old 11-17-2011, 09:45 AM
bczee's Avatar
I just used a Oil Pan Drain plug.. with the correct threads (I don't recall right now). But it is a common part at most parts stores. (Dorman)
Old 11-17-2011, 08:23 PM
LSCustoms's Avatar
the threads/bolt is a 20mm x 1.5, it will say that on the package, I picked mine up from a place called OReilly's out here and autozone could have ordered it... NAPA had it also... and may hardware stores
Old 11-19-2011, 11:17 PM
Mike52's Avatar
Thanks for the info guys, I picked up one at Advanced yesterday, was only a couple of $$. Dorman part #65221, it's exactly like the one in LSCustoms' pic.
Quick Reply: Oil Level sensor plug
