Straight-Up Thermostat Housing
Well I searched the archives but didn't see an aftermarket housing available for sell for less than $100. So I decided to modify the one I have by cutting it at a 35 degree angle, rotated it around so it would be a "straight-up" housing.
But before having the housing tig welded, I wanted to remove the thermostat from the housing but it appears that it's "riveted" to the housing (?) . I didn't want to drill the rivet out, then have problems later.
Stock position.
Modified position before tig welding.
Stock position.
![](http://pic10.picturetrail.com/VOL326/687113/5551618/120468282.jpg)
![](http://pic10.picturetrail.com/VOL326/687113/5551618/120468283.jpg)
Before I cut, fitted and brought this housing to the welder to be tig welded,
I called them yesterday and was told they didn't make a housing for it, only for 283-400 sbc intake manifold??? Do you have a stock number?
BTW I also called Billet Specialties and was told the same thing
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Okay guys, I called again and spoke to the Tech Dept and was told they DO sell them. Click on "search" and punch in the
Part number 911LS1 for $34.77.
Well as the adage goes, "ask and you shall receive"...thanks LS1Diva![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Well now does anyone know if the Vortec 5.3 housing is the same as the LS1 housing?
![](http://www.csr-performance.com/Merchant2/graphics/00000001/CSR_LS1.jpg)
