s10 ls1ers
Old Jun 29, 2006 | 07:38 AM
  #541
'JustDreamin''s Avatar
Originally Posted by Bigdeezs
Well I finished building my 1.75" long tubes ...WHATTA BITCH! Took me about 2 weeks of cutting fitting and welding. I cant beleive how much time they took me. Now I know why custom headers cost so much.
I guess that means you don't want to build a couple dozen sets for the rest of us.....
Looks great! Once they're Jet Hot'd, they ought to look fantastic!
'JustDreamin'
Old Jun 29, 2006 | 10:57 AM
  #542
NO-OPTION-2002's Avatar
New question...
Has anyone used a sanden compressor in the factory low mount location? And does that fit without notching the crossmember?
Sorry for all the q's...
Trying to plan before I get the truck.
Old Jun 29, 2006 | 04:28 PM
  #543
On 1-1-06 ls6jimmy posted
GM makes 3 4l60e tranny's: one that doesn't have a removeable bellhousing and 2 that has a removeable bellhousing. One of those is designed for LSX series and the other for s-10, astro vans, and full size trucks with the 4.3. If you want to use your tranny then this is what you have 2 do(b/c this is what I did) change the bellhousing to a LSX bellhousing, the input shaft, and stator.
Please correct me if i'm wrong, but, couldn't we use the 6.0/4L80 flexplate and spacer, and avoid tearing into the trans?
Wouldn't this be just like putting a 350/400/700 behind an LS1? Or, am I missing (misunderstanding) something?
Old Jun 29, 2006 | 04:32 PM
  #544
Bigdeezs's Avatar
Originally Posted by NO-OPTION-2002
Bigdeezs...
Those are damned impressive. Congrats.
'JustDreamin'
Thanks for the positive comments and NEVER AGAIN!!...LOL
Old Jun 29, 2006 | 06:34 PM
  #545
firefighter's Avatar
Deez's don't be that way man! We were gonna get a group buy together.
Old Jun 29, 2006 | 06:44 PM
  #546
So-GT0071's Avatar
wow this quite an LS1 S10 thread! How many people in here actually have an LS1 in their s10/sonoma?
Old Jun 29, 2006 | 07:50 PM
  #547
Jhankinson's Avatar
I do I do...there are actually quite a few people with them in S-series vehicles.
Old Jun 29, 2006 | 08:20 PM
  #548
Bigdeezs's Avatar
Yup...me too! Mine's been in for a while now! Do you actually have the LS1 in yours too or is your sig soon to be LS1?
Old Jun 29, 2006 | 10:38 PM
  #549
Neaolas's Avatar
Originally Posted by Jake the SSnake
Hi everyone first post here. Been doing a lot of reading on the LSX swap into a s10. I currently have the 5.3 motor and am putting it in a 99 Sonoma. From what I have read you need the c5 alternator/ps acc. for the swap but it looks like the truck in those pics is using the truck mounts? Will the truck mounts in fact work?
Old Jun 30, 2006 | 03:19 AM
  #550
AceHaag's Avatar
yes they will with some modification. That is what i have in mine. i had to modify the p/s area to mount the 2.2 p/s pump the original pulley was too big of a dia.
Old Jun 30, 2006 | 04:30 AM
  #551
So-GT0071's Avatar
My truck is all in pieces right now...basically...the ls1 and trans are mounted.....will be getting to work on wiring this weekend and I should be getting my corvette bracketry either tomorrow or the next day. Going to pick up my headers this comming saturday. So as you can see I am well into the swap, I'm just at the point right now where everything needs to be hooked up. I was hoping to get this done before school starts back up...but I only have untill the beggining of april before it starts, at this point I don't think I will get done untill beggining of september sometime....I have no idea what I'm gonna do about getting home from my highschool in the afternoon.....owell as long as I have an LS1 in my truck...it doesn't bother me..
Old Jun 30, 2006 | 04:53 AM
  #552
So-GT0071's Avatar
Oh...also thought I'd ask, what are you guys doing for a cooling system? What kinda fan, radiator, etc. I live in Arizona..so it gets hot, plus I'm retaining A/C. I'm thinking 4.3 radiator(while LS1 is mostly stock, later get one fabbed), puller fans of course(not sure what kind?), headers will be jet hot coated, will be putting a cowl hood on the truck. I figure all that and a coolant additive will keep the truck cool? Suggestions?
Thanks.
Old Jun 30, 2006 | 05:58 AM
  #553
Jake the SSnake's Avatar
Thanks.
I was going to use the stock 4.3 radiator until I found out their are 2 kinds.A 1 1/4-1 1/2 (cant remember which) in 4x4's and most auto 4.3's and a 5/8 in manual trans,I have the 5/8 radiator . I will be buying the be cool radiator from jegs for about $320,and using ls1 fbody electric fans.I think the fans will fit w/minor trimming.
Old Jun 30, 2006 | 06:55 AM
  #554
Jhankinson's Avatar
I used the 4.3l Auto Radiator....its i think 1 1/4" with 2 SPAL fans....driver side is a 14" and pass side is a 12". It is tight with the F-body spacing....but does fit...and cools great. i have a 160* tstat and have the #1 fan programed to turn on at i think 180 and off at 173...and the #2 fan to come on at 195 and off at 184. On my aeroforce scangauge....it has never even gotten hot enough to turn on the #2 fan. I dont have a/c yet...but i do live in FL where we see pretty warm temps also. So I dont think the A/C will make it go over the #2 fan capability....it will idle all day is traffic at about 180 to 185. These aluminum block motors dissipate heat tremendously fast. Hope this info helps.
Josh
Old Jun 30, 2006 | 10:18 AM
  #555
AceHaag's Avatar
I'm running the 4.3 radiator with 2 13" pusher fans that i modified that came out of a lumina mini van w/3.8. holds 190 no problem in 80* weather. here is a pic of the fans
Old Jun 30, 2006 | 01:41 PM
  #556
So-GT0071's Avatar
alright sounds good. My truck was originally an auto 4.3 so I had just bought a new 4.3 radiator like 5 months ago or so because my old one was leaking. So I'll use that and I was thinking Fbody fans as well. Did you guys have to move the radiator forward at all? My LS1 is set back about as far as possible so I'm hoping I won't have to.
-Taylor
Old Jun 30, 2006 | 05:02 PM
  #557
ls6jimmy's Avatar
Yep I found out that my 4.3 radiator isn't liking the 95-100 degree weather here especially in traffic so I ordered a Be Cool. I saw someone esle is ordering a Be Cool they have 2 different versions one is 379 and the other is 599.
Old Jun 30, 2006 | 07:42 PM
  #558
Yeah I've heard the 4.3L rad is kinda hit or miss it either works or it doesn't the BeCool will def get the job done. Kinda like going after it with a shot gun some times a lil too big is the way to go. Example we are having a really hot summer workin us over right now an it is only gona get worse. My teuck is pretty much stock and it's been running like 215*-220*. So what the hell is that rad gonna do for me when I put the LSx in there?
Old Jun 30, 2006 | 08:57 PM
  #559
Xtremes10's Avatar
well got my headers from JTR, here are a few pics, i gotta get the pics of the motor mounts if anyone wants to see, thruck is going to be in pieces starting this weekend, then the motor is coming out and getting sold with tranny, powerdyne charger, headers, full exhaust, so yea, its only got 37,xxx miles on it, and wasnt driven hard, so if you know anyone that wants one, LMK but here are the headers
Old Jun 30, 2006 | 09:06 PM
  #560
Xtremes10's Avatar
JTR has aluminum corvette rads that fit with their mounting brackets for about $100 or so less
