s10 ls1ers
Old Mar 3, 2008 | 10:10 PM
  #1541
Bigdeezs's Avatar
Originally Posted by drwoowoowoo
Just a couple of pics from this weekend, you know its a sad day when yo put a kit on your ride to try and get around a trailblazer. We had a problem with the nozzle i put on the truck, the fuel pills were to much for the juice so we cut the fuel noid outta the picture and ran a dry shot it was only a 50 dry shot it was a fender the whole way until he hit his second stage and made it a 1 car difference
Get that fuel figured out and you will have no trouble. I've run one w/basic boltons and murdered him. If the guy you were runnin was squeezin that much you should be running at least a 100 shot. My motor loves the spray.
Old Mar 3, 2008 | 10:43 PM
  #1542
lt1s10's Avatar
H3 pan
Old Mar 4, 2008 | 02:04 AM
  #1543
BluLS1's Avatar
Originally Posted by lt1s10
H3 pan
is your crossmember cut?
also whats up with the steering shaft there?
Old Mar 4, 2008 | 08:02 AM
  #1544
lt1s10's Avatar
Stock cross, the steering is modded for header clearance.
Old Mar 4, 2008 | 08:28 AM
  #1545
black2002ls's Avatar
How far below the cross member is the pan? I'm seeing varying results. Also, is there any bind with that steering set up?
Old Mar 4, 2008 | 09:35 AM
  #1546
lt1s10's Avatar
It hangs about 1/2" down at the lowest point (the oil drain). The steering is as smooth as ihop pancake batter.
Old Mar 4, 2008 | 01:55 PM
  #1547
Bigdeezs's Avatar
LOL
Old Mar 4, 2008 | 03:05 PM
  #1548
m8w6r77's Avatar
which fuel pump are the 1 gen guys using. i am wanting to buy a racetronix fuel pump kit with the hot wire kit. i see there is GN kit. will that work? a lot of pages to go through hoping someone could tell me off the top of there head. lol
Old Mar 4, 2008 | 06:40 PM
  #1549
drwoowoowoo's Avatar
Ya i had way to small of a pill in the nos side .022 this is all new to me
i got a .065 and a .038 on order
Old Mar 5, 2008 | 01:44 AM
  #1550
Bigdeezs's Avatar
looks like about 150...nice
Old Mar 5, 2008 | 03:17 AM
  #1551
Bigdeezs's Avatar
LOL my GF was watchin some vids on youtube and she found my truck...check out 3:13...its me racing a centrifugal supercharged 1997 cobra on PCH like two years ago! (I'm much faster now)
http://www.youtube.com/watch?v=YEf7xQbnQf4 <---Skip to 3:13
Old Mar 6, 2008 | 06:41 PM
  #1552
its a 125, i have some tr6s in it now. Im gonna see how well she responded to the gear change and exhaust job, Then im gonna put the 100 pills tag it when i hit 3rd. Then try and leave on it. She how she likes it, put the 125 tag it in 3rd, then try and leave off the line on it as well... Im piecing together a dry shot kit for the truck. Ls motors seem to come alive on a dry shot as compared to the wet stuff, so who knows maybe we can get close to knockin on that low 7 second door
Old Mar 15, 2008 | 05:23 PM
  #1553
cavmattz24's Avatar
...what is this doing on page 4??
Old Mar 19, 2008 | 02:35 AM
  #1554
BluLS1's Avatar
i know this is off subject from yall, but i was wondering what wires i need to jump on the plug for the clutch safety switch that was on my manual tranny pedal assym. i'm going automatic. i think there are four wires if i'm not mistaken two to start and two for cruise.
Old Mar 19, 2008 | 09:47 AM
  #1555
OTBlazer22's Avatar
BigDees, I noticed that you had said that your motor sat way lower than with the regular mounts. Ive read this ENTIRE thread. Could you tell me what mounts/how its mounted and what pan/what had to be done with the cross member? PM is fine, or on here. I would really appreciate it.
Old Mar 19, 2008 | 02:05 PM
  #1556
Bigdeezs's Avatar
I took f-body mounts and cut them to fit. My Blazer had engine mounting towers that would have raised the engine about 1-2 inches. I sliced those off and welded the f-body mounts directly to the frame with the engine as low and far back as I had room for.
Old Mar 19, 2008 | 02:58 PM
  #1557
OTBlazer22's Avatar
im assuming but not certain that your older 2nd gen and my 02 blazer frames are identical. So i dont need to spend a chunk on the s10 mounts, i can just modify the f bodies. this is good news
Old Mar 19, 2008 | 07:30 PM
  #1558
This is a pretty good topic for discussion. I drive an 03 S-10. How similar is my frame going to be to your blazers? Do you have any pics?
Old Mar 19, 2008 | 08:39 PM
  #1559
Bigdeezs's Avatar
Here you can see how and where I welded on the camaro mount. There was a mount tower in that location previously. I dont think s-10s had the tower though.
Old Mar 20, 2008 | 03:11 PM
  #1560
OTBlazer22's Avatar
do you recall where you bought your f body mounts from?
