s10 ls1ers
Old Dec 3, 2007 | 11:13 PM
  #1341
LSXS10's Avatar
Well we were kinda on subject!! at least its an s-10 and an ls motor but we did....
Old Dec 4, 2007 | 01:19 AM
  #1342
Ls2Sonoma's Avatar
lol
np
its all good reading!
Old Dec 4, 2007 | 11:30 PM
  #1343
01WS6/tamu's Avatar
My turck has the full zq8 suspension and wheel package. I put a set of two inch blocks in the rear to level it out. Has anyone seen how a set of 245/50/16 tires would like with this combo. I haven't even seen it with a stock tire since the rims are still in the boxes waiting for me to decide on wht rubber size to use on it. I am really leaning towards the BFG KDWS for their Z speed rating. I just am not sure with a tire this short if the wheel well would like a cavern or pretty good. If you have some ideas shoot em. This week the exhaust is getting put on. After that I have a ton of pictures to put up. Oh this is an extended cab stepside.
Old Dec 10, 2007 | 10:14 PM
  #1344
01WS6/tamu's Avatar
Lights are on but no one is home it seems. Had a wedding pics up later this week.
Old Dec 11, 2007 | 07:40 AM
  #1345
Frank02L's Avatar
LSXS10: are you running caltracs?
Old Dec 11, 2007 | 08:10 PM
  #1346
LSXS10's Avatar
Nope, just some homade slapper bars and stock leafs..I do want to try a set though if it doesnt hook with the motor upgrades if ive get e-nuff power next year i WILL 60' 1.20s on a 275 drag radial!!!! Im just worried how bad the cage will upset how the truck works, the cage will weigh about 140ish so i want to loose that much up front so a man. rack and areospace brakes are next....
Old Dec 12, 2007 | 06:40 AM
  #1347
Frank02L's Avatar
We had a set of slide a links to go on it but I've seen some pics of what they've done on higher power setups on 1st gen f bodies and novas and stuff. So we are sending them back and putting caltracs on it. Thats what I run on my Lightning as well.
Old Dec 13, 2007 | 01:07 PM
  #1348
lt1s10's Avatar
I need some pics of motor mounts and starter clearences... I can install my engine about 3 different ways and Im wondering what is the right one. carshopinc/ ebay mounts. thanks a billion. JZ
Old Dec 13, 2007 | 03:52 PM
  #1349
01WS6/tamu's Avatar
Using an ls 2 pan and trans dapt mounts. Mine wound up with about a 1/4 inch from the back of the head to the A/c case. I set it as far back as I could and in the middle of the engine about two inches to the left of the oil pressure sending unit there is about three inches to the firewall. I have about 3/4 of an inch from the coil on the drivers side by the brake booster. I am using the round truck coils. I sat mine down as low as I could go. With it set right there the tie rod clears the fron of the oil pan by about an 1/8 of an inch when you turn the wheel hard left. I notched the **** out of the crossmember for the pan and to clear the compressor. I am running all vet accessories. I used the tiny starter from an 04 up FS chevy truck and it has tons of room around it.
Old Dec 13, 2007 | 04:17 PM
  #1350
lt1s10's Avatar
got a part number or a link to that starter?? I was under the impression that any gm gear reduction starter would fit. just how small is this thing?
Old Dec 13, 2007 | 04:35 PM
  #1351
fast's Avatar
8.5" was available in 2wd from 95-03
as well as some 4wd and awd
best being the ZR2 w/ 3.73 gears
Old Dec 13, 2007 | 06:05 PM
  #1352
01WS6/tamu's Avatar
Any of the gm starters will work the newer one is just a more compact design than the older ones. Not sure on a part number I found mine in a salvage yard off of a truck with about 300 miles on it.
Old Dec 13, 2007 | 06:21 PM
  #1353
LSXS10's Avatar
If you cant find one at a salvage yard Summit sells a mini tq. "summit brand" I bought it for less than an autozone starter 150 or so i think....and its kinda pretty toooo.
Old Dec 16, 2007 | 10:10 PM
  #1354
01WS6/tamu's Avatar
I scored a great deal 35.00 on an 02 zq8 steering box with 13K friday. For those of you who have gone from the stock box to the quick ratio was there a noticeable difference in road feed back and overall feel of the vehicle etc. I just got it put on a few mintues ago.
Old Dec 16, 2007 | 10:39 PM
  #1355
01WS6/tamu's Avatar
One other question just to see where most people sit. I have built many engine harness' before... So, running short on time and patience and money is also running thin. I have my 02 6 cyl harness and an 02 f body engine harness I can extend the pcm connections and lay the two harness into each other and make it every bit as turn Key as CPF harness. Should I do it or just put a turn key harness on my paid off credit card and be done with it.
Old Dec 16, 2007 | 11:44 PM
  #1356
Ls2Sonoma's Avatar
take the 02 harness, seperate all the sensor wires from eachother, then extend the wires to meet up with the pcm and repin it
Old Dec 18, 2007 | 11:39 AM
  #1357
Jhankinson's Avatar
if you can do it...do it yourself. Its not that hard of a task...and then you can say you did it
Old Dec 24, 2007 | 02:34 PM
  #1358
Sparkinak's Avatar
So this is where some of you guys hide at!!
Old Dec 24, 2007 | 08:48 PM
  #1359
01WS6/tamu's Avatar
Old Dec 24, 2007 | 09:39 PM
  #1360
4by364's Avatar
Great info here, I plan on starting my swap well tonight or in the morning... Blazer is in the garage getting warm!!
