s10 ls1ers
Old May 31, 2007 | 09:05 PM
  #1141
almostfast's Avatar
Originally Posted by 01WS6/tamu
Up up. does anyone know how to post pictures directly here?
1. go to photobucket.com and host your pics there
2. go into the picture you want in the album and click the IMG code (there will be like three different ones, but IMG is the right one...)
3. it will say "copied"
4. go to your post and put the cursor where you want the picture, then press CTRL and V at the same time
5. see...
Old Jun 2, 2007 | 12:54 AM
  #1142
eagleuh1's Avatar
Thanks almostfast. Being computer illiterate, thats helped me post my first pic.
Old Jun 2, 2007 | 12:56 AM
  #1143
eagleuh1's Avatar
Ahhggg, how do you make them smaller? Is there a sticky for posting pics?? LOL
Old Jun 2, 2007 | 01:04 AM
  #1144
eagleuh1's Avatar
More pics of my 96 S10 Blazer with 5.3 at eagleuh1's album on photobucket.com
Old Jun 2, 2007 | 11:05 AM
  #1145
almostfast's Avatar
https://ls1tech.com/forums/showpost....78&postcount=8
Old Jun 2, 2007 | 12:07 PM
  #1146
Ls2Sonoma's Avatar
we dont want them smaller!
Old Jun 5, 2007 | 04:30 PM
  #1147
thehemi's Avatar
Originally Posted by sr_ryan1
The corvette alternator bracket, power steering pump, pulley, power steering reservoir, hose, and balancer will have to be used in order to make clearness.
I'm installing a 4.8 into my '92. Do I need this setup?
Will the factory 4.8 accessories not clear in my truck?
the stock F-body manifolds are the only ones that will work for s-10's.
98-99 F-Body manifiolds? Or will any year LS1 manifolds work?
And what are people doing for a y-pipe behind F-body manifolds?
Old Jun 5, 2007 | 08:29 PM
  #1148
Jhankinson's Avatar
98-99 will only fit with mods to the flanges....and the Y-pipe...exhaust shop takes care of it when you get exhaust done...or fab one up yourself.
Old Jun 5, 2007 | 10:24 PM
  #1149
brentg454's Avatar
Has anybody tried the f-body oil pan? It looks similar to the LS2 pan, but can be had for cheaper. I thought I saw somewhere where somebody tried this. I searched this thread, but the only info I see is for the LS2 and truck pans.
Old Jun 5, 2007 | 10:56 PM
  #1150
eagleuh1's Avatar
Yep. 98-99 fbody manifolds cut off the flange and weld on extensions. I used v-flanges to connect to homemade y-pipe. Muffler shop can also expand pipe over the extensions and put band clamps on the overlap. 7 bucks for nice clamps at truck shop. Truck accessories can fit. Its tight on the alternator though. Delete the purge solenoid and engine cover and you can use the truck intake. Must notch for AC compressor in original location. Must notch for truck pan except in 4x4 Blazer with front differential removed like mine. Good luck with yours.
Old Jun 5, 2007 | 11:03 PM
  #1151
eagleuh1's Avatar
Cowl hood soon to be made I think.
Old Jun 5, 2007 | 11:06 PM
  #1152
eagleuh1's Avatar
98-99 f-body manifolds modified, and homemade y-pipe
Old Jun 6, 2007 | 10:12 AM
  #1153
brentg454's Avatar
hey eagleuh1, is that the Snuggle fabric softener bear in the first pic?
Nice work on the y-pipe - I plan to do exactly the same thing on mine.
Old Jun 6, 2007 | 12:55 PM
  #1154
sdimess84's Avatar
Whats the best way to delete the purge solenoid off of the truck intake? Mine is hitting my hood when it closes and i think is causing a vacume leak....
Old Jun 6, 2007 | 01:51 PM
  #1155
thehemi's Avatar
Interesting idea. I need to convince the wife that I
need to get myself a welder in the real neat future..
Will the stock truck PS pump and brackets work okay?
I think the theory has been using a Corvette PS setup,
but maybe that's only if you're using a real LS1 engine?
Does anyone have a pic of the crossmember notched?
I'm curious how much is actually needed to be cut out?
The theory is an LS2 pan will require a little less cutting?
Old Jun 6, 2007 | 02:19 PM
  #1156
sdimess84's Avatar
Here are some pics of the ls2 pan notch on my 96 s10.
Old Jun 6, 2007 | 07:12 PM
  #1157
eagleuh1's Avatar
Brentg454, no, thats not the Snuggle fabric softner bear, thats my dogs surregate sex partner, when no females around, well, you get the idea. Right there its just propping up the metal box so my manifolds dry faster. The dog was real worried for a while.
Old Jun 7, 2007 | 05:50 PM
  #1158
Sabre002's Avatar
So has anyone done a Turbo 5.3 truck motor in a 91 bodys style S-10 I'm thinking about doing this to mine. But I would like to keep AC so I'm not sure if I will be able to use the truck manifolds in the budget turbo system on this site.
Here is the truck
Old Jun 8, 2007 | 11:26 AM
  #1159
CobraSpdRH's Avatar
Can anybody tell me what all is needed to swap in the T-56? I have the tranny already but do I need the master and slave out of an F-body? If so are there certain years that have less problems than others? I thought I read somewhere that the 98-99 are prone to problems?
Thanks for the pics of notching as well, I am putting an LS2 pan on mine as well
Old Jun 13, 2007 | 01:40 PM
  #1160
V8sonoma's Avatar
will the factory s10 clutch master cyl. and line work the the t56 slave?
