s10 ls1ers
Old Aug 22, 2007 | 07:13 PM
  #1181
Ls2Sonoma's Avatar
i had it running awhile back... not sure when, maybe early june? and yes, it had quite a miss to it... very noticable while driving/accelerating, turns out it was a bad coil or two. swapped to MSD coils awhile back and cleared my airbox more for the fuel rail cover. so far ive over 2000 miles on it!
i still have the stock rad and it cools great. i had it up in the mountains in hot weather and its never been higher than 200°F
Old Aug 23, 2007 | 10:42 AM
  #1182
s10-den's Avatar
Bro, I thought it was the cam actually...glad you got it going....weighed it yet with the ls sitting in it?
Old Aug 25, 2007 | 03:06 PM
  #1183
almostfast's Avatar
anyone know if, or how well handheld tuners work with an LS1 S10? if they do work, what one would allow me to:
1. recalibrate speedo/ shift timing (I'm pretty sure they all do that)
2. change fan ON temp... ( think they all do that too...)
3. remove AIR pump trouble code (I dont have the pump in the truck and I want that light OFF permanently!)
Old Aug 25, 2007 | 05:03 PM
  #1184
Ls2Sonoma's Avatar
almostfast.. you could get a hold of hypertech or superchips and ask them directly... you know, do some research. i know that hptuners works great and allows you to change tons, doesnt sound like what youre looking for though
havent weighed it yet, Jody... but i should hey? lighter than the 4.3!!
Old Aug 27, 2007 | 08:41 AM
  #1185
s10-den's Avatar
yea man,just wondering the weight
Old Sep 3, 2007 | 04:40 PM
  #1186
almostfast's Avatar
ahh... this truck hates me!
took it for a drive today, and it drives fine if you were going for gas mileage, but when you step on it, it cant make up its mind if it wants to kickdown and go or if it doesnt... it gets like 40% through it and then it goes back up a gear... I really dont know what to look for now... it fights the whole swap, and then for months after its done... jeez neverending battle
anyone know what might make it do this?
Old Sep 5, 2007 | 09:57 PM
  #1187
northcoastrides's Avatar
[QUOTE=Sabre002]So has anyone done a Turbo 5.3 truck motor in a 91 bodys style S-10 I'm thinking about doing this to mine. But I would like to keep AC so I'm not sure if I will be able to use the truck manifolds in the budget turbo system on this site.
Hey Sabre I have a 91 shortbed with a 5.3 you can keep the a/c after you notch the frame rail the truck accessories work if you sit the motor to the rear I'm not familure with that turbo setup but the truck manifolds don't fit at all use the f body manifolds or sanderson headers like I did they fit great and look way better then manifolds
Old Sep 6, 2007 | 12:02 AM
  #1188
Ls2Sonoma's Avatar
check your tps pos. i wonder if the pcm is seeing WOT too early. bad sensor or wires
is the pcm stock?
Old Sep 6, 2007 | 04:00 PM
  #1189
almostfast's Avatar
we changed the tps, it could be the wires though... have to check them... yea, the PCM is stock...
Old Sep 6, 2007 | 04:23 PM
  #1190
Jhankinson's Avatar
Well got the new cooling fans in and decided to clean up and take some new pics of the LS1 S10. Its the first time I have shined it up, cause smoking the tires just makes it dirty so damn fast!! So its finally done and home. Now for the never ending tweaking and toying
Old Sep 6, 2007 | 08:03 PM
  #1191
Ls2Sonoma's Avatar
ya, check to see that your reference wire has low impedance
Old Sep 6, 2007 | 09:04 PM
  #1192
Bigdeezs's Avatar
ahhhh com'on don't tease...where's the engine bay pics?
Old Sep 7, 2007 | 08:54 PM
  #1193
rollinphat4me's Avatar
hey jhankinson,the outside of your ride looks sweet,but i agree with deez stop teasin lol and show us your motor pics
Old Sep 9, 2007 | 09:55 AM
  #1194
almostfast's Avatar
well, I found out why it was dying off at high rpm... it only has 20 psi of fuel pressure... im getting REALLY SICK of this fuel pump crap... next pump will be #5...
Old Sep 9, 2007 | 05:01 PM
  #1195
Jhankinson's Avatar
OK guys..heres the under hood shots...a bed shot..and an interior shot. Hope ya like it. Just to prove yes its it is an LS1
And for those who wanna see all my pics I have right now...along with some videos I am loading now...here is the link to my photobucket page
http://s101.photobucket.com/albums/m52/jhankinson/
Old Sep 10, 2007 | 04:58 PM
  #1196
almostfast's Avatar
problem found... fuel pump blew the intank connection hose to $#!+... now i need another hose that will handle the 58psi, and will last while submerged in gas...
oh and nice job Jhankinson... looks good... and yours has fuel pressure
Old Sep 13, 2007 | 11:04 PM
  #1197
eagleuh1's Avatar
JHankinson, does your computer require a serial data signal to start the ac compressor. My 2005 5.3 does. Haven't figured out yet how i'm going to get it working.
Old Sep 14, 2007 | 06:23 AM
  #1198
Jhankinson's Avatar
No..since I am running a LS1 program I dont have that issue. I talked to Jared at CPW and he mentioned to me about the differences in truck vs Fbody programs and that was one of them. Have you tried to talk to him. Sometimes he takes a while to get back to you...but he knows his stuff. I am sure there has to be a way to change it away from serial data.
Old Sep 14, 2007 | 06:10 PM
  #1199
01WS6/tamu's Avatar
Jhankinson. Was Jared able to get your gas gauge working correctly using the fbody program.
Old Sep 14, 2007 | 06:11 PM
  #1200
eagleuh1's Avatar
Hey, thanks. No, I haven't talked to him. It's getting cool here now, so I'll probably take my time getting to it. I was also wondering if HPTuners might be able to change that requirement.
