s10 ls1ers
Old Jan 14, 2007 | 07:51 PM
  #961
Bigdeezs's Avatar
I like the Nittos but a buddy with a 03 cobra had them and they only lasted a lil over a year. So I know they wont last long but thats the price I pay for traction. As for the fronts, I have some junk sumitomo HTR Zs that I had on another set of rims for a long time...they are 255-45-18s. They've lasted a long time but I dont know if I'd recommend them. The Blazer also sits a little stink bug with the tire size difference. I may try to fix it with larger diameter fronts but turning radius is already hurtin some so we'll see.
Originally Posted by firefighter
Deez how do you like those Nittos? I'm running the BFG KDW the flame tread 245/45-18 in the front and 285/40-18 rear well they are gonna need to get replaced this year and I'm looking into new sizes and maybe a new brand. BFG doesn't make at least the rear size you listed. what are you running in the front?
Old Jan 14, 2007 | 09:47 PM
  #962
firefighter's Avatar
stink bug? as in high in the front or rear? see with my tire sizes they arwe essentially the same diameter just different widths. but as with everything I want more and I know I can fit more tire under there.
Old Jan 14, 2007 | 10:25 PM
  #963
Bigdeezs's Avatar
Before the tires had a 5-6 drop but I raised the rear to get more travel so now its a 5-5 drop. The rear looks higher now after these tires whereas it looked level with the same diameter tires before.
Old Jan 15, 2007 | 07:32 AM
  #964
so stink bug means *** up? sorry just never heard the expression. also a side note the 285's rub a little too only if I hit a ramp type surface. what I'm thinking about doing though is when I do the rear (8.5") I'll make it 1" wider 1/2" per side, to get some inboard space but not to pass the fender I might roll the inner fender and trim the fender flares (it's an Xtreme) the wider track can't hurt either.
Old Jan 16, 2007 | 07:32 PM
  #965
rollinphat4me's Avatar
hey deezs,did you post a video of your ride going down the track at fontana? i seen it on streetfire videos,and if it was you,dammmmm your truck sounded great!!!!!!!!
Old Jan 16, 2007 | 08:13 PM
  #966
GR33N GoblinM6's Avatar
in that case.. i did my wife "stink bug style" last night
Old Jan 16, 2007 | 08:16 PM
  #967
Xtremes10's Avatar
I have never heard of it as stinkbug, just as raked, btw, I figured out my problems with the harness, it was on our end, not speartech's
Old Jan 19, 2007 | 11:36 AM
  #968
CobraSpdRH's Avatar
So I guess I might as well jump in now. Been browsing for awhile but my conversion is underway so it's time for me to start posting. I have a 98 reg cab 4-banger thats receiving the swap treatment.
So far it has G-body QA-1 coil over kit up front and drop leafs and new shocks out back. I have an 8.5 rear ready to go in, along with Global West tubular upper control arms and a 12 inch brake upgrade using their junkyard parts (Cadillac spindles, camaro calipers, etc.)
I just bought my T-56 and a H/C LS1 minus the wiring/pcm and haven't decided whether or not to run carbed or buy a PCM and have Current Performance make me a wiring harness.
Oh and it is sitting on 17x9.5 TTII's
Anyways, plent of question to come from me so be prepared lol. Thanks
Rob
Old Jan 19, 2007 | 08:35 PM
  #969
Bigdeezs's Avatar
hehe..yeah thats me thanks
et streets: http://videos.streetfire.net/video/w...b60189520e.htm
nitto drag radials: http://videos.streetfire.net/video/w...b7001005da.htm
Old Jan 19, 2007 | 09:17 PM
  #970
Xtremes10's Avatar
hey, bigdeezs, what did you do for traction? and what kind of power you making? I am thinking about buying traction bars but im not sure.
Old Jan 19, 2007 | 10:05 PM
  #971
Jake the SSnake's Avatar
Drag radials and cal-tracs or comp engineering "slide a links" are a good setup.
Old Jan 20, 2007 | 08:23 AM
  #972
Xtremes10's Avatar
we saw a guy with a 2000 s-10 at the track, 355 headers cam ect ect, with home made slapper bars running 12.20's
Old Jan 20, 2007 | 09:46 AM
  #973
CobraSpdRH's Avatar
http://www.hotrodsandhemis.com/Traction.html
Doesn't seem like it would be too complicated
Old Jan 20, 2007 | 10:01 AM
  #974
Ahhh the wonders of the internet. You look long enough you'll find anything you want and how to do/make something.
Old Jan 20, 2007 | 12:04 PM
  #975
Xtremes10's Avatar
I am not too worried about driveability, i kind of lost that factor with the cam and the stall, I only want this to be a once or twice a week thing, its going to be on a trailer to and from the track, and well, the only times i'll take it out are weekends to a car cruise or if its nice out just for a ride, so it really doesnt present a problem having a stiff suspension, because there was a point i was thinking 4 link with tubbed rear
Old Jan 23, 2007 | 09:52 PM
  #976
Xtremes10's Avatar
today was like christmas in january, got my bullet mufflers, electric fans, battery box, water temp and oil pressure gauges, traction bars, thermostat, and tranny cooler all at once today! will have pics soon
Old Jan 23, 2007 | 10:30 PM
  #977
Bigdeezs's Avatar
Just tires...I make 390rwhp on the motor and 500rwhp on the unit (125 shot).
Old Jan 24, 2007 | 03:15 PM
  #978
01WS6/tamu's Avatar
I have checked current performance and really like the harness' he makes but. Considering mine is simpler since it's a 96' sonoma and I have a perfect 02 f-body harness how many of you think it is worth the time to fab it myself and I can integrate it into another factory harness so it will be plug and play when I drop it in. I have built my own harness before and never had any trouble but it was out of necessity. The turn key harness is nice but when factored in with all of the extras that always come up when doing a swap such as this I am wondering whether the extra money is best spent elsewhere. I am going to run fans and all of the other good stuff. But since it is an older truck it is a lot more straight forward. We also have alldata at the shop so schematic access is not an issue. what do you think. Thanks
Old Jan 25, 2007 | 01:21 AM
  #979
Ls2Sonoma's Avatar
making your own harness, regarless of year of your truck, is retarted simple. the only issue you need to deal with is the stock gauge cluster's tach reading from the new pcm
Old Jan 25, 2007 | 07:12 AM
  #980
Xtremes10's Avatar
i would say have the harness re worked by current performance or speartech, however, i was left with the issue that the harness was still set up to go over the intake manifold, so i have to find a way to hide a gigantic mass of wires
