Can I lengthen mass air wires?
I wouldn't. I am not positive about it, but I think it would be a bad thing. Those wires are sending extremely precise voltage signals to the PCM. Even the best soldering may cause a small voltage drop across that wire. You can buy MAF wire extensions for the LT1, so I assume those or other extensions would work for the LS1.
LS1 MAFs send a frequency signal, not analog voltage. I say go for it. If soldered, your connections will have lower resistance than the connector in the extension harness.
With solder it'll be fine but... you CANNOT lengthen the wires for the O2 sensors. I tried it once and the solder wouldn't even melt. The wire seemed like it was made of steel or something. Had to throw a new O2 sensor in the trash...
sawzall wielding director
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
You can't lengthen the o2 wires itself. You have to extend the wiring harness side. If you extend any input/reference wires then use shielded wire to block out EMI.
-Alex
-Alex
I had to extend a few wires on my engine, like starter motor and crank angle sensor, so far so good with crank angle sensor, well engine seems to run normal.
Just use good wire, same size and amp and solder or use good connectors, do a check before and after as well.
Old post bump from the dead. Found it searching this question:
Is there any wiring in the harness that's sensitive to being lengthened or shortened? The VSS twisted pair seems like it might, but that's just a guess.
A little lengthening or shortening wouldn't bother most items UNLESS you end up with a bad connection making a section of wire transferring less amperage than the original size. As a drastic example , a large battery cable with only a few strands remaining in a damaged spot will still read correct voltage, but not allow enough amperage to start a car.
So lengthen or shorten correctly & no need to worry. I usually like to use extra comparable wire from another car harness, as parts store wire can be much lower quality.
I was about to jump into the convo and just happened to notice the date posted was from 2006, wow you did some digging for this thread lol.
