Waterpump/heater hose fittings.
What are you guys using for waterpump/ heater hose fittings. I just got a new waterpump and it needs 90 degree fittings where the heater hoses attach. Right now the one on the car has some plastic pieces friction fit and I want something a little better. Was thinking AN 90's with pipe thread, but what size?
I knocked out the steel hose barbs and welded on some AN #10 fittings. I've then got a couple of 120 degree Earls hose ends and 5/8" braided hose. The aluminium AN #10 weld on fittings are anly a few $$ each and any good welding shop should be able to weld them on for you.
Cheers
![](http://www.clubcobra.com/photopost/data/500/Engine_Bay_01.jpg)
Cheers
The connections for my heater core don't extend through the fire wall. I got a pair of AN10 bulkhead fittings and modified them (I haven't got any pics of them installed yet). The bulkhead fitting has a male AN10 on each end and is threaded in the middle so you can put it through a hole in the fire wall and secure it with a nut. The longer end on the inside of the firewall I machined down into a barb to suit regular 5/8" heater hose. in behind the dash I'm just using regular heater hose to go from the bulkhead fittings to the heater core.
Cheers
Cheers
I wanted to keep the engine bay as clean as possible so machined up some aluminium brackets for the coils and re did the loom.
Here's a pic of the coil brackets:
![](http://www.clubcobra.com/photopost/data/500/medium/coil_brackets.jpg)
Here's one mounted in the end of the foot box:
![](http://www.clubcobra.com/photopost/data/500/medium/Engine_Bay_05.jpg)
I'm getting a set of custom length leads made up shortly. just got to get my headers baolted on again and measure them up. It'll be interesting to see how they perform.
Cheers
Michael
Cheers
Michael
I tapped each hole 1/2"NPT and then used one 90 ell (AN-10 to 1/2NPT) and one straight (AN-10 to 1/2NPT) then used one straight, and one 90 degree AN hose fitting. Just be careful tapping out the smaller of the two holes. I ruined one water pump b/c the casting cracked; newer water pumps (04 and up) have more meat in that area and I had no problem (with the newer pump)
The following users liked this post:
Homer_Simpson (05-06-2024)
