Upgrades for your conversion
Old Mar 27, 2006 | 11:23 AM
Schitzo's Avatar
Default Upgrades for your conversion
For those who have done or are doing a LS1 conversion, what kinds of upgrades have you done to your motor? I am thinking cam or LS6 intake and maybe a LS6 oil pump. I just don't think I would stick it in there stock....I have tinkeritis bad
Old Mar 27, 2006 | 11:43 AM
55chevy's Avatar
I had a '01 motor so I already had the LS6 intake. In addition to my signature items, I put in a ported oil pump and LS2 timing chain. The chain is a little heavier duty than the LS1 chain and didn't cost much. I still have not fired her up yet.
Old Mar 27, 2006 | 12:10 PM
Brains's Avatar
LS6 intake
Bo White ported heads
220/224 .581/.581 114+4 "quiet cam"
Long tube headers, high flow cats
3200 RPM Vigilante converter
Magnaflow catback
NX Nitrous kit
Old Mar 27, 2006 | 12:58 PM
Oscar Will's Avatar
I went with the "hot cam" kit valve springs and ZO6 intake along with the C5 timing chain and guide kit. Aside from that was a complete balance job and blueprinted it during assembly.
Old Mar 27, 2006 | 01:07 PM
YsoFast's Avatar
If you start with a block is everything else a mod?
Old Mar 27, 2006 | 01:12 PM
nitrovette's Avatar
i started with a new 99 block and put 2004 internals into it with a ls6 intake,mahle file to fit rings,arp bolts,ls6 oil pump.
Old Mar 27, 2006 | 02:49 PM
Stu Cool's Avatar
Mine started as a 2000 TransAm. LS6 intake manifold, LS6 PCV conversion as documented at LS1Howto.com, LS6 Valve springs, Yank Stealth 2800 converter, ETC throttle. Performance will also benefit from the Sanderson Headers and Flowmaster true duals, and I chnaged my rear end gears from 2.79 open to 3.80 posi.
Other than that I left it stock.
Pat
Old Mar 27, 2006 | 05:50 PM
Bo White's Avatar
Originally Posted by Brains
LS6 intake
Magnaflow catback
NX Nitrous kit
Got it runnin yet there Brains?
Old Mar 27, 2006 | 07:00 PM
digitalsolo's Avatar
I ported the stock manifolds (well, 2001 manifolds), put in a cam, ported oil pump, upgraded springs/ti retainers, stall converter, nitrous, and upgraded the rod bolts and replaced the bearings with Clevites.
Tossed in a new style LS2 chain while I was at it as well as all new gaskets.
Old Mar 27, 2006 | 07:22 PM
67RSCamaroVette's Avatar
'98 LS1
upgraded to 01 heads+ valve covers,
LS6 intake,
ASP pulley,
MSD wires, (3 stockers broke)
Pacesetter LT's,
RAM clutch,
ported tb,
!air, !egr,
cam coming soon, once it's running..
olly
Old Mar 27, 2006 | 08:24 PM
redaddiction's Avatar
Bored and stroked 6.0 block to 423 does that count as an upgrade
Oh yeah and blinker fluid
Old Mar 27, 2006 | 08:35 PM
Schitzo's Avatar
having read all that you guys have posted, I think I am going to go with an LS6 intake, underdrive pulley, LS6 oil pump and Edelbrock long tube headers....for now anyway.....cam,heads and tune will have to wait....$$$ is tight
Hiiii ...its my 100th post
