A/C compress options?
Old Mar 29, 2006 | 12:58 PM
Bo185's Avatar
Default A/C compress options?
I got a 2001 Voretec 5.3 in a 73 Scout II and I am trying to get the A/C up and running. I have the stock 5.3 truck compressor mounted in the stock location and it's tight the problem is the A/C lines will not hook up with out being in the way of the exhaust or engine mount.
Are there any options as far as a universal A/C lines to hook up to the stock truck A/C compressor. The A/C line I got of the donor truck doesn't fit at all. Would the lines or compressor of an vette or F-body work some how? I need A/C! I have seen the high mount stuff but the compressor fits so I would like to keep it in the stock place just get some kind of A/C line that will work.
Thanks!
Old Mar 29, 2006 | 03:00 PM
Brains's Avatar
You can adapt the lines over to stainless braided if you like, by tapping the block that bolts to the compressor and using O-ring NPT to pipe adapters. I'm thinking about doing that on my LS1 Mustang project if I can't get the factory lines to reach (looks to be way too short for the really long Mustang engine bay).
Old Mar 29, 2006 | 04:02 PM
Andy1's Avatar
You might try giving these guys a call; HotRod Air They've always been very helpful.
http://www.hotrodair.com/
Andy1
Old Mar 29, 2006 | 04:15 PM
jeepinpete's Avatar
Default A possible source
I came across this site: http://www.rayeveritt.com/
Prices seemed very reasonable, but I have no first hand experience. I haven't gotten that far...
Pete
Old Mar 29, 2006 | 08:17 PM
John McGraw's Avatar
I had clearance problems my LS2 in a 65 Corvette, and ended up using a F-body compressor. The F-body comperssor has a rear exit, and has hard lines that tuck in tightly to the body of the compressor. One line runs underneath the compressor, and one runs on top. Here is a pic:
http://img.villagephotos.com/p/2003-...3/P0001348.jpg
You will notice that I had to trim the edge of the motor mount a little, and I had to trim the back of the compressor bracket to clear as well. This sure beats having to go to a set of custom brackets and compressor like I had to do on the LS1 in my 59 Corvette. Also, the F-body compressor is smaller in diameter than the LS2 compressor, although it has a smaller pulley, which means it turns at slightly higher RPM.
Regards, John McGraw
Old Mar 29, 2006 | 11:53 PM
Bo185's Avatar
Looks like just what I need! Will the F-body compressor fit the stock truck compressor mount or does it need its own mount bracket. And will the thing line up and engauge the crank pully correctlly? Thanks!
Old Mar 30, 2006 | 10:00 PM
Same mount, and everything lines up.
Old Mar 31, 2006 | 01:05 AM
Bo185's Avatar
Sweet! Now all I have to do get one! Thanks, I was worried I would have to move the engine!
Oh, F-body P/N on A/C compressor and lines?
Old Mar 31, 2006 | 10:59 AM
Mark IXZD 150's Avatar
I have one! I have a practically new 2002 Camaro LS1 (1400 miles) compressor with all the fittings off the engine I used in my Corvette. e-mail me at mark2000ss@comcast.net
