LS1 into a TT 300ZX
What if I pulled the stock V6 and swapped in an LS1? Would it be possible for the LS1 to fit and hook up the stock turbos? I'm thinking it would require a set of custom exhaust manifolds. I'm really hesitant to do this though since the engine bay in that car is so damn tight.
Good luck with the project!
http://www.gulfgt.com/forum/showthread.php?t=5181
another one
the upgraded turbos for a vg would probably work great on a ls1, but i doubt youd be able to keep the exhaust or anything, youd need to fabricate oil lines, chargepipes, exhausts, turbo mani's, and the obvious mounting equip for lsjuan, and possibly a driveshaft as well, but that would be a great swap if you have the resources.
If you really wanted turbo, it would be easier all around to go single turbo LS1.
Andrew
