O2 Sensor
Old Apr 30, 2006 | 10:38 PM
AaronH's Avatar
Default O2 Sensor
I need an O2 sensor with longer wires. Any reason I can't find one from another GM vehicle? Do they all work the same? Does anyone know of a particuler part number or model that has a longer wire harness?
Thanks
Old Apr 30, 2006 | 10:42 PM
gogogadget's Avatar
I use a rear sensor from an ls1 corvette. You can probably find the exact one through a search, but they are really long and work as a front would.
Old Apr 30, 2006 | 10:45 PM
G-Body's Avatar
sawzall wielding director
For the front or rear, I know that they make extension harness for the rear. Or you can just add some length to the wires on the engine harness. Just make sure you solder and shrink wrap the wires, and don`t try to extend the wires on the O2 side of the connector they are made of stainless steel or something and virtually impossible to get solder to stick to. If you don`t need to replace the O2`s I wouldn`t, they are pretty expensive.
Old Apr 30, 2006 | 11:02 PM
AaronH's Avatar
I found out tonight that solder won't stick to the wire on the sensor side...dammit. What are the chances that the connectors are the same from the corvette rear harness?
Thanks
Old Apr 30, 2006 | 11:09 PM
G-Body's Avatar
Yep I found that out the hard way too.
Old May 1, 2006 | 07:35 PM
Monza355's Avatar
Do you know if the connector for the o2 sensor is the same for all GM's?
Bill
Old May 1, 2006 | 10:50 PM
G-Body's Avatar
Bill
I don`t think it is, I know that the connectors for the front and rear O2 sensors on a truck are different, and neither one matches the connector for rear o2 sensors on an f-body
Old May 2, 2006 | 08:11 AM
Hersker Hans's Avatar
do an ebay search, ive seen they got extensions there. Or you can splice in a wire yourself to make it longer?
Old May 2, 2006 | 09:56 AM
70 LS1's Avatar
Conversion master
All of the vendors that sell headers sell extensions. You have to use them if you run long tubes. I think they are about $12 or so.
Old May 2, 2006 | 11:41 AM
Scooter70's Avatar
Thanks
100%. That's what most of the F-body guys with headers use.
