truck vs F-body oil pan?
does anybody have measurements on the F-body Oil pan? Mine is installed in my truck but I mounted the engine lower than normal (fabed my own mounts) and now I am concerned it is too low, the oil pan is slightly below the cross member. I dont know that I will have any problems but it makes me nervous,
If it will fit I will be looking for the complete pan and pickup tube and stuff...
thanks
Dave
thanks
Dave
wow thanks, I had looked on their site but hadnt found that. That is just what I needed. I am going to compare to my truck one but looks like I will be looking for a setup...
do I just need the pan and pickup tube?
I hope to find one pretty cheap.
Dave
Dave
You need pan, pickup, windage tray, dip stick, and tube.
(Not 100% sure about the tube and dip stick)
Windage tray is shorter than the truck tray.
Just put mine on last weekend...
I looked for a month on ebay and here. Best deal I found was $135 shipped for everthing.
New everything is around $250 I think.
You can alway check out the Cadilac CTS-V oil pan. it is not as low as a truck and not as long (front to back) as a F-body. I am using one in my 71 Chevelle. S&P has the compare on there web site...
I think a new oil pan will run u around $230+ retail, not including the windage and pickup or dip stick and tube.
Originally Posted by Derek 357i
Any dimensions on the LS2 vette pan?
Thanks all, I did some measuring last night and am now looking for either the Camaro stuff or the Caddy stuff, it appears like either will fit my application.
Thanks again
Dave
Thanks again
Dave
