69 camaro whats it worth?
I have a 69 x66 lemans blue camaro i am looking to sell.
The bad news 1st no engine/trans or front clip, interior.Rear quaters had the lips cut off, deck lid is pinned on and the passenger door has the webbing cut out so it would need to be replaced.The floor has some holes where at one time a roll cage went thru.no title
The good news it was never titled and never on the street so there is no rust anywhere.It has all the glass and regulators except the windshield. Has bumpers and wiring harness, taillights, grill , new seal kit , and other misc. stuff.has disc brakes
so what should i ask for it?
Thanks for your help! Ken Brandt
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
not to mention no title...means race car only... can't drive it..because you can't get registration
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Originally Posted by holley505
That is all you got my man... it is tough to say... somebody would spend big bucks to make a car out of what you have... you are better offer EBAYING this as a parts car start and 500.00 and see how much you can get...
you can have a builders title made for the car if you wanted to put it on the street
built correctly it'd be worth ALOT. Not a lot of those.
L34 Engine; 350-hp Turbo-Jet 396-cid V-8 (requires Camaro SS) $184.35, 2,018 built.
L35 Engine; 325-hp Turbo-Jet 396-cid V-8 (requires Camaro SS) $63.20, 6,752 built.
L78 Engine; 375-hp Turbo-Jet 396-cid V-8 (requires Camaro SS) $316.00, 4,889 built.
L89 Engine; 375-hp Turbo-Jet 396-cid V-8 with aluminum cylinder heads (requires Camaro SS) $710.95, 311 built.
guessing its an X66 car?
edit:
got pics?
edit:
got pics?
the reading I have done I didnt think you could tell between a big block or a small block the only designation was V8. Is that not true? Now I know there is a difference in the heater box but I did not think there were any number differences.
Dave
Dave
Dave
Dave
Originally Posted by SatisTraction
it is most likely a x66 car. to be honest it could be worth 500-5000 depening on what the tag says. post a pic of the vin and the tag and we will get you some info.
i know where there is a comlete x66 car for $2500 but it has some rust issues![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
TR 711 71 71 PNT
06A X66
Originally Posted by 67RSCamaroVette
there are a number of different places you can get info from, the trim tag has an X designation that says what the basic car was, and there are little clues on the rest of the car that show what its options were. '67's had LOTS of info on the cowl tag, 69's, not so much.
Thanks for the info
Dave
