ls1 fuel line question.
thank you.
ryan
On the back, using the plastic tank, the easiest way is to use the fourth gen fuel filter and all metal lines connected to it. Stock the fourth gen has a T connector that will thread right into the 3rd gen feed line. This will handle fuel and return. For EVAP (if you're keeping it), use your old return line and just hose clamp it to the right line on the 4th gen tank. You can then remove your stock EVAP line.
If your tank didn't come with the filter, T, and lines you need to buy some. You can fab some up if you want, but anything else you might as well not use the plastic tank.
Kevin D.
Kevin D.
you can also use compression fittings to seal a connection to a hardline and then thread on a barbed fitting which you can clamp a soft hose over.
or use any of the stainless braided line methods and fittings... kinda pricey.
there are some stock GM options also, look in the thread stickied at the top of this forum about LS1 swaps in a 67 or something like that... there is some fuel line info in there.
good luck!
98-04 fbodies have the regulator and all the return stuff inside that tank.
98-04 fbodies also use a returnless fuel injection setup.
the only thing you need to do is make sure there is a fuel filter in there somewhere and use the feed line right to the motor. you can find the push connect fitting everywhere. including all the sites that specialize in conversion cars!
good luck its a simple task once you start researching
Kevin D.
The CFR can be mounted near the tank and its return line can then be run right back to the tank with a short line. The main fuel output line then goes straight to the fuel rail. The 2000 LS1 only has one connection on the fuel rail.
I would recomend getting the intank pump from a Camaro with an LS1 or a Walbro pump. I have been told the Camaro pumps are quiet where my Walbro intank pump has a slight wine to it, but it works great.
The only other fuel setup you can do is to run both a supply and return lines to the engine bay to a pressure regulator where you can dial in the 58psi then a single outlet from the pressure regulator to the fuel rail. You should place a filter inline between the tank and the regulator input, and you will still require a high pressure intank pump.
the best and cheapest option is to put an inline pump with the vette regulator and just plug and play
also all the fbody fuel rails from 98-04 have the single input on the fuel rail.
you can get a 97-98 vette Y-body fuel rail and it will have a feed,return, and regulator on the rail which might make a cleaner install. but you will still have to put a bigger pump there
