lt1 to ls1 convertion
Old May 26, 2006 | 10:41 PM
tyler ovel's Avatar
Default lt1 to ls1 convertion
i would just like to know if there is any thing special that i need to know about doing this convertion. I already have the ls1 dash, kmember, motor, wiring but idont know if there is something else that i might run into
thank for your time
Old May 26, 2006 | 11:08 PM
ROCNDAV's Avatar
Tranny? Gas tank & pump? rack & pinion? How much are you changing over? Some have done it very minimally, I am replacing just about everything.
Old May 30, 2006 | 01:02 PM
tyler ovel's Avatar
thanks for the reply but why do you have to change the gas tank and pump, they should be the same I thought??? and to answer your question I'm just replacing the motor with a stock ls1 w/compcam 230/232 and kook long tubes. i'm also getting a genuine vipper six speed with a mecloud twin dics clucth to go with it. that is all that i can afford right now, so it will have to do. p.s. good luck with that convertion from a v6 to a v8
Old May 30, 2006 | 02:04 PM
ROCNDAV's Avatar
You don't have to change it, but I am basically changing everything over. Don't the LT1s run at 3 bar pressure where the LS1's run at 4 bar? Are you going to keep a return fuel line, if so, you'll also have to modify your ful rail or get a 97 Vette fuel rail.
As for the Viper T56, make sure you check the tail shaft, input shaft, front plate and bell housing for differences when mouting up an LS1 (and drive shaft yoke).
Old Jun 1, 2006 | 12:47 AM
tyler ovel's Avatar
thanks for the advice about the trasmittion. I had already bought all that with the trany. but as far as 3 bar 4 bar pressure system i dont know what your talking about. thanks again tthaough for your adive , it was much appreaciated
Old Jun 1, 2006 | 02:33 AM
ROCNDAV's Avatar
As far as I know the LT1's used 3 bar fuel pressure where the LS1's use 4 bar (58 psi) fuel pressure. I'm not sure if simply going with an aftermarkter racetronix will work for you or not. I opted to go with the whole tank/pump assy.
Old Jun 1, 2006 | 04:34 PM
1bdbrd's Avatar
im doing the same swap, or atleast getting parts for it. speartech told me that unless i really want the ls1 dash it would be easier to convert without it. they said to modify the stock wiring harness and use a 99+ ls1 harness and computer. they said with that harness and the water temp sensor from a 98 ls1 all my stock gauges would work correctly.
just something to consider.
Old Jun 1, 2006 | 11:45 PM
tyler ovel's Avatar
thanks for the tip 1bdbrd but iwould rather have the ls1 dash in my car.
Old Jun 1, 2006 | 11:50 PM
tyler ovel's Avatar
thanks for the info ROCNDAV but do you know if I can just use a ls1 fuel pump assembly for mylt1 gas tank. thanks again and I appreaciate you taking the time to help me.
Old Jun 2, 2006 | 11:22 AM
ROCNDAV's Avatar
I'm not sure if a 98 pump ***'y will work, as 98's were the only LS1 F bodies with metal tanks. 99+ used a plastic tank. The mounting of the pump housing assy is dofferent between plastic & metal tanks. One screwed on and one bolted on (IIRC). I ended up going with the plastic style tank & pump assy but actually ordered a Racetronix pump/kit. I have yet to get that far in my project (the pump, tank & rRacetronix stuff is sitting on a shelf in my garage).
You might be able to ask in the fuel section whether a 98 LS1 pump assy cant mount into your LT1 tank. Not sure about the fuel lines either. I believe the LS1 is returnless where the LT1s had a return system. Once again you can modify a 98+ LS1 fuel rail or get a 97 Vette fuel rail (which used a return line), but I'm not sure if that also requires the use of an adjustable regulator when doing that.
Old Jun 2, 2006 | 11:44 AM
FANTAZ28's Avatar
Moderator
make sure you get an ls1 rack, i used my stock fuel line with a 97 corvette rail and regulator.... very easy.
there are pics of the car in the july issue of gmhtp if you wanna see what an ls1 looks like in there
Old Jun 2, 2006 | 07:56 PM
tyler ovel's Avatar
thanks for the info ROCNDAV and ONYOURLS1 it is much appreaciated
Old Jun 2, 2006 | 08:08 PM
1bdbrd's Avatar
ls1 rack? as in the rack and pinion? i was told by severl who have done the swap and also read on here that even if you use the ls1 k member you dont need a new steering setup? i want to make sure as i wasnt planning on getting a new one..
Old Jun 2, 2006 | 09:09 PM
ROCNDAV's Avatar
Yeah, you need the rack, but you can keep your steering wheel/column.
Once day, I will get pictures and post them as a step by step, but at the rate that I am moving, you'll probably finish yours first
Have you checked out Magnus' website?
http://www.dxsoftware.com/magnus/
Old Jun 2, 2006 | 09:19 PM
ROCNDAV's Avatar
Here are some more great links that I have bookmarked over time. I need to go over some of these again
https://ls1tech.com/forums/showthrea...&highlight=3.4
https://ls1tech.com/forums/conversions-swaps/216921-1995-v6-ls1-lt1.html
https://ls1tech.com/forums/conversions-swaps/215071-3-4l-ls6-conversion.html
https://ls1tech.com/forums/showthrea...66#post1780266
https://ls1tech.com/forums/showthrea...0&page=2&pp=20
http://www.torquecentral.com/showthr...4&page=1&pp=25
http://www.pbase.com/mavness/getting_the_v8_in
https://ls1tech.com/forums/showthrea...23#post3019123
https://ls1tech.com/forums/showthrea...ht=dash+wiring
Old Jun 3, 2006 | 01:09 AM
FANTAZ28's Avatar
Moderator
yeah you need the rack for sure, the ls1 block is wider and where the shaft goes into the rack is more towards the driver side tire on an ls1 ... the lt1 is more towards the middle and wont fit
Old Jun 3, 2006 | 09:30 AM
mpe331lx's Avatar
Subscribing (Possible ls1 swap into 97 v6 Camaro)
