Pic's of my 5.3L swap in an S-10
YES IT IS A 5.3L it just looks like an LS1
The Modifications:
Vehicle: '2002 Chevrolet S-10 Xtreme
Engine: 5.3
Mods:
Nelson performance tuning,
2001 5.3L engine
2000 LS1 intake manifold and injectors
Comp cams 216/220 .525/.532 114LSA
Comp Cams 918's
Comp Cams Hardened push tubes.
Custom cold air intake
Sanderson 1.5" primary short tube headers.
Custom 2.5" Y-pipe into single 3.5" through dynomax bullet and
flowmaster 40 series.
MSD wires, NGK TR6 plugs
ASP Underdrive pullies.
ARP Rod Bolts
Electric fans
B&M Hammer Shifter
FJO Racing Progressive Nitrous controller
BBK SSI Intake and 80MM TB (not shown)
YANK SS3600 Stall converter.
Trans-go HD-2 Shift kit
Corvette Servo
3.73's
Zexel Torsen Differential
TA Performance Girdle
Competition engineering Slide-A-Links
Mickey Thompson 255/50/16 Drag radials.
1/4 Mile times stock converter: Before Intake, Throttle Body, and Yank converter
N/A 13.55@103.4 MPH 2.01 60'
Progressive 100Shot: 12.59@114 MPH 1.99 60'
The Modifications:
Engine: 5.3
Mods:
2001 5.3L engine
Comp Cams 918's
ARP Rod Bolts
Electric fans
B&M Hammer Shifter
Corvette Servo
3.73's
That is the cleanest conversion i have ever seen. The 5.3 looks right at home between s-10 frame rails. I hope to do a 6.0 or 5.3 conversion on a 95' s-10 set-up for bracket racing.
One question about it....what A/C relocation is that....is that a Sanden 508. And how much room is there around it....I have a 1994 S10 that is 95% complete...but I still have to work out the A/C stuff...and I like that look you have there. Also what did you do with the 2 rear coil packs?? Truck looks awesome....I hope mine turns out that well.
So you used the round style truck coils and bracket...and you were able to clear the Brake Booster and the A/C box without any problems. What year did yours come from....cause if that is the case...i am going to find me some of those.
Very nice looking. Only hope my Bravada will look 1/2 as good when I'm done.
Question: What changes did you have to make to the fuel system (specifically fuel pump)?
'JustDreamin'
'JustDreamin'
haha...one more question....what did you do about the oil pan. Did you use a truck pan....so it hangs down about 2" or did you have it modified. I am wondering because mine hangs down about 2" and it kinda worries me. Thank for all the great help.
