Do I need to ground my battery directly to my block?
Right now I have my relocated battery grounded to my frame (piece of 2x4 box tube) and my block grounded to my frame with some huge 2/0 cable. Is it neccasary to run another cable from the battery directly to the block?
I have grounds running from the battery to 1) Frame, 2) Engine and 3) body... I also have grounds from the engine mount bolts to the x-member. Back of the heads to the Body. And that is just in the Engine Area.. Have a few Frame to body grounds around the trans and rear frame area (Gas tank and trunk). If I find any good reason for some electronic stuff.. i will add more.
thats cool, im not saying its wrong to have plenty of grounds, i just figured if anyone is planning on beefing up their stereo they should keep that in mind is all. the way i was told you just want as many of your grounds going to the same place. i.e. kinda like how you have a postive power juntion and all the positive wires join there, same kinda thing.
