russell fuel rail fittings
Who has in stock the russell fuel rail fittings? Summit wont have them till 9/8. I need 2 of the 3/8 to 6an and 1 5/16 to 6 an. Also, what is everyone using for radiator hoses in their swap? This is going in a 72 camaro. Thanks, Josh
Whats the correct part number. I got mine at Speedway 640853 and 640863, the box says LT1/LS1 rail but then don't fit. Anyone have the correct mumber?
Thanks
Tom
Edit: Went to Speedway tonight and they got an order from Russell in and all the 3/8 adapters where actually 5/16 in 3/8's package.
Thanks
Tom
Your local industrial hydraulic place should have compression fittings that will work well. You will need a AN-6 to AN-6 union.
Check out C4 Corvette radiators for a good, low cost, light weight option.
Andrew
Andrew
I've used swagelock compression fittings extensively in compressed gas applications. They are an excellent alternative to having to flare the end of a piece of tubing.
http://www.swagelok.com/search/produ...t=SS-600-6-6AN
Something like that will work great. You can also use them on the filter/reg.
