Started the first try
back on topic. yes it is the vats causing that problem. its cutting out the fuel. get a bypass box to fix that.
https://ls1tech.com/forums/conversions-swaps/567630-homemade-vats-bypass-box.html
Or you can send it out to a place like speartech and get it programmed out totally.
Justin
So when I got up this morning I decided that I should check everything again to make sure I didn't miss something. Well guess what, I had a large hole without a plug in it on the back of the j-tube for the supercharger, a GIANT vaccum leak
I installed a cap in it and no more starting and dying.
Here is a vid of what it sounds like with open manifolds running the way that it should [IMG]
[/IMG] Trending Topics
Justin
it died after running only a few seconds. It does this everytime
does that mean that my VATS didn't get disabled? Here is a video of it wanting to run [IMG]
