Going to build LS1 S13....Need rigidity input...
Any help appreciated.
-Chris
now that im done being an *******, you dont need to do antyhign to the chassis.
I'd hate to see you do the swap, which doesnt look like you know much about (theres alot of info on here) and then have to twist your body. You can get a motorset anywhere from 4000-6500 some get luck and can track one down for $3500. The stock chassi will hold an LS1 just find if you really think you might need something to keep it together than get a custom cage via your local cage builder. But seriously its not needed. Rubber mounts and independent rear subframes (READ NOT SOILD REAR AXLE) allow room for toruqe to be distributed without "twisting" the frame.
Im just looking to cam it spray it Hinisons long tubes and a stock 4.08 vlsd rear with solid aluminum subframe spacers.
