pics lq4/lq9 + fox stang + 4.6 mounts = no workie
Old 09-27-2006, 07:18 PM
kosmo38's Avatar
Default pics lq4/lq9 + fox stang + 4.6 mounts = no workie
looks like the iron 6.0 block missing important third hole. dammit.
any alternatives or will i have to pony up for the aje ls1 k member. i already have the 4.6 k member and mounts got the stang as winter project as the 7 is in the final stages. feel free to go through my album
http://s49.photobucket.com/albums/f2...o382/?start=40
[IMG][/IMG]
[IMG]
Old 09-27-2006, 09:02 PM
Brains's Avatar
What about building a set of solid motor mounts? Seems trivial enough, unless you really want poly/rubber mounts.
Old 09-28-2006, 08:11 AM
kosmo38's Avatar
i dont have a welder or fab experience??? would you like to make me a pair?? name your price. it would be greatly appreciated.
Old 09-28-2006, 08:35 AM
Brains's Avatar
How soon do you need 'em? If you're not in a huge hurry, I can handle it in the next couple weeks.
Old 09-28-2006, 11:09 AM
kosmo38's Avatar
not in a huge hurry. i can wait a couple of weeks. let me know when your ready to ship so i can send you the cash. its for a notch with a stock 4.6 k member. by the way how much??
Old 09-29-2006, 09:55 PM
PRAY HRD's Avatar
i'd say dump the iron block and do go the aluminum route, but perhaps i'm a little biased. really though, the aluminum block would be a Much better choice for an already light car to kind of balance it out, but if money is a concern, that's completely understandable. i would like to see the car either way when it's up and running! what's your overall plans for the car? feel free to shoot me a pm if you'd prefer not to clog up your thread too btw.
-Dave
Old 09-30-2006, 12:14 AM
vanilla89's Avatar
my motor mounts use just the front four holes they are 79 mustang motor mounts with a 1/4inch thick plate that is mounted over the holes
Old 09-30-2006, 12:18 AM
b00sted's Avatar
It would probably be cheaper to just motor plate it and be done with it.
Old 09-30-2006, 01:55 AM
jbk240z's Avatar
Lightbulb How about..............
an adapter plate of sorts? Using 1/4" or 3/8" steel plate depending on preference, install the front 2 bolts through motor mount/adapter plate and thread into block as normal. The rear 2 of the 4 bolt holes on the block would be attached through the adapter plate via counter-sunk bolts. The third motor mount hole then bolts to the extended adapter plate. This idea will raise the engine slightly, but the elongated holes in the 4.6 k-member should allow for that. Anyway, just an idea.
Old 09-30-2006, 10:35 PM
nuckifuts's Avatar
AJE now makes LSx/FOX kmembers?
Old 10-02-2006, 02:03 PM
STL2SLO's Avatar
TTT for nuckifuts question.. I would like to know the answer too!
Old 10-02-2006, 02:07 PM
Brains's Avatar
Why not go ask them, and report back?
Old 10-02-2006, 02:33 PM
Mr. Hyde's Avatar
Not exactly. They offer a SBC swap k-member and motor mount kit that will fit an LS1, however the clearance between the oil pan and k-member is 3/8" with spacers that I had to fabricate, and the clearance between the steering rack and oil pan is very similar. Without the spacers it was touching. I did email back and forth with Anthony Jones to try to remedy the problem, and his solution was for me to fabricate spacers The good news is that there was no work needed on the tunnel to fit my T-56. The shifter hole is about 2" back too much for an exact fit, but in my case (no center console needed) it's ok. Not sure what that means for headers, but I'll be trying to fit a pair of the MAC mid-lengths this weekend, when they get here.
Old 10-02-2006, 07:28 PM
kosmo38's Avatar
i do have some 1/4 steel that i can play with.ill toy with it just incase brians dosnt come through with the solid mounts.
-Dave
i have a aluminum ls1 but its kinda being used in this
i would agree but no one offers a ready to install kit. im really tight with time as i have to get the 7 at least started by the 28 of this month for my b day.
that ysucks especially for the $469 price tag it carries. i thought from what i was told from aje it was ls1 specific. ill be waiting for brians solid mounts but will look into the other options
Old 10-03-2006, 01:08 PM
Mr. Hyde's Avatar
Yeah I was also told that it would work as if it was LS1 specific, but it really isn't. I know that with any conversion there are always issues like this, but I'd think that the manufacturer of a a specific product would actually know how well it does or does not work, and not just blow smoke up your *** to make a sale.
Old 10-03-2006, 03:57 PM
71c10AZ's Avatar
Mr. Hyde, thanks for the heads-up on the AJE k-member. I almost bought it a few weeks ago; glad I didn't! I wonder if their 4.6L k-member would work better?
Old 10-03-2006, 04:49 PM
Brains's Avatar
Search in this forum The K-member questions have been answered already, quite a few times
Here, I'll even make it easy for you --- ls1mustang.com
Old 10-03-2006, 05:02 PM
I8URLS1's Avatar
Mr Hyde I was planning on ordering that k-member as well this coming weekend. Could you potentially fabricate me those spacers? If so PM me. And also do you have to pay extra for the mounts to make an LS1 work? I'm doing a 6.0 as well into an SN 95 but with forged internals and a vic jr. setup. Just gonna go carb to keep it simple.
Old 01-23-2007, 05:10 AM
tirefryin_s10's Avatar
this is an old post but i think jbk240z hit the nail right on the head with the small adapter plate .... spacing it up slightly might even be good by the sounds of some using the tubular aje k member ? now another question which k member fits the best a 4.6 conversion k member for a fox or a 96-04 tubular k member that was factory equipped with a 4.6?
Old 01-23-2007, 08:49 PM
Flashman's Avatar
96+ k-member...modify the 4.6 mounts to fit the LS1
Quick Reply: pics lq4/lq9 + fox stang + 4.6 mounts = no workie
