A/C on 68 fire bird LS1
Old Oct 23, 2006 | 12:28 AM
jsconiers's Avatar
Default A/C on 68 fire bird LS1
Running a BRP modified subframe with an ls1 out of a 98 camaro. Just purchased the LS1 but it came without accesories. After looking at the 67-69 camaro sticky I noticed that the A/C will not work on the 1st gen F-body. I would like to run a vintage air setup if possible. what are you guys doing to fit the compressor / A/C into the car? Are there brackets that some one has available and would I need to change any of the other accesories out?
Old Oct 23, 2006 | 06:36 AM
Steve68's Avatar
You need to check out the thread at the P/T board, I and a couple of others have been discussing it regularly,
Old Oct 23, 2006 | 08:41 PM
67ls1CamaroProject's Avatar
I have posted many times before way back when I did my swap....the Vintage air system WILL WORK FINE with the stock LS1 compressor. My swap is going on 4 years old and still blows ice cold air! Enough theorizing, just do it.
Old Oct 24, 2006 | 05:23 AM
Steve68's Avatar
WoW, thats good to know, I wass told by people in the business, they wouldn't work together, well it would then it would self destruct, thanks
Old Oct 24, 2006 | 06:52 AM
I am in the business. Electrical engineer who now owns an auto repair shop. Not that this is worth anything. The proof is under the hood of my car. Still no self destruction....at least not the a/c part anyway.
Old Oct 24, 2006 | 08:43 AM
Steve68's Avatar
Did you make a pocket in the subframe or just move the plates you made for the engine to accomadate the compressor,
Old Oct 24, 2006 | 08:58 AM
John McGraw's Avatar
The stock compressor will work fine, but is large and harder to find a place for. The Sanden compressor and the S&P passenger side low compressor mounting makes for a real compact compressor layout. The S&P setup moves the compressor forward so that it is driven by the same belt as the water pump, and moves it very close to the block. This gets the back of the compressor away from the motor mounts, and avoids the need to grind on the mounts to clear the fitting block. I will never mess with a stock compressor again, the Sanden compressor is just an easier fit in most cars.
I chased my tail for days trying to use a stock compressor on a 65 Corvette, and while I finally got it to fit, I realized that I could not change a compressor without pulling the engine! I finally caved in and bought the Sanden setup.
Regards, John McGraw
Old Oct 25, 2006 | 05:23 AM
Steve68's Avatar
John, can you post a link to this, S&P's site wasen't working for me the other day,
Old Oct 25, 2006 | 08:32 AM
http://www.hotrodlane.cc
Old Oct 25, 2006 | 09:24 AM
Steve68's Avatar
PDF down loads, yawn, thanks
Old Oct 25, 2006 | 10:36 AM
ss496's Avatar
all my a/c stuff fits just fine, but im using an aftermarket subframe....all i had to do was clearance the motor mount a little
Old Oct 25, 2006 | 01:14 PM
Steve68's Avatar
Key words "aftermarket subframe" I would use one too, but I did mine long ago, thanks
