tranny cross member
on my car we had to modify the arm length and height of the mounting position because of changes we made to the engine position and height.
Go here and pull down about 1/4 of the page to see the dimensions http://www.rowand.net/Shop/Tech/Auto...issionSwap.htm
The 200r4 needs to be built up in order to handle large amount of power. Standard 200r4 can not handle much power (except if they are the Turbo Buick ones) without breaking. Many of the aftermarket Trans built have some good built up packages and only need the correct Cable and a 12v+ source (and switch).
One plus is that the 200r4 is much lighter in weigth as compared to the TH400 / 4L60(e)'s.
You might look into some of the chevelle aftermark/remakes as they do market 200r4 crossmembers, maybe looking at one of those x-members might help out to see what is needed to fab or mod your x-member.
Powerglide - the early GM 2 speed
TH350 - light to medium duty 3 speed
TH400 - Heavy duty 3 speed
TH200 designed in the 70`s as a lighter replacement for the TH350 for use with 4 and 6cyl engines (3 speed).
200R4 a redesign of the TH200 to make it stronger and add an overdrive (4 speed)
700R4 a clean sheet design, not related to any of the older stuff, overdive 4 speed meant to be stronger than the 200R4.
4L60 same as a 700R4, the name (designation) was just changed.
4L60E same as a 700R4/4L60E, but it is electronically controlled.
4L80E A redesign of the TH400, but it is electonically controlled, and has an ovrdrive (4 speed).
