So here's the game plan 00 Mustang + LSx + huge turbo :)
Old 06-29-2007, 10:27 AM
  #221
7 Second Club
Phil99vette's Avatar
Haven't made much progress lately because I've been alittle under the weather. But here is where we're at...
- Just got word from ETP that the LS7 heads will be done monday and Kurt is going to pick them up for the o-ring work monday night, We switched over to titanium/inconel valves and a solid roller valvetrain.
- Jesel just completed the replacement set of LS7/J2K rockers and they are on the way
- C & R called and the radiator is done, they are waiting on the Extreme 3000cfm fan, will ship today one way or another
- Metal express sent out the parts to finish my fuel tank/water cell mounts(1" tubing) and the aluminum sheetmetal to fabricate the turbo inlet.
- Global Technology sent:
9' of 5" aluminum Tubing for the exhaust
2' of 6" tubing for the turbo inlet
4 90' SS elbows for the radiator pipes
2 90 AL elbows for the water cell, IC outlet, and Y block
Wolfe Racecraft just sent
2 - 4" aluminum o-ringed V-band clamps
Still need to order:
Back brace for rear
-12 fuel feed lines and fittings
-10 fuel return lines and fittings
Misc fittings for fuel pressure regulator
16 volt battery
Motor is done @ the machine shop, all we're waiting on now is the heads to o-ring the block and the studs to retap the head studs.
Old 07-07-2007, 12:42 PM
  #222
7 Second Club
T T T more updates coming this weekend.
Old 07-08-2007, 01:32 AM
  #223
1dirtyZ's Avatar
is it the weekend yet??
Old 07-08-2007, 05:53 PM
  #224
Cam72aro's Avatar
+1. We want pictures, more pictures.
Old 07-08-2007, 08:38 PM
  #225
slammer454's Avatar
yeah, i want more pics of this beast!
Old 07-08-2007, 09:25 PM
  #226
7 Second Club
Damn, this weekend flew by. I was building a cage for a 1st gen Talon this weekend and really didn't have time for the mustang but I did get a few pics....
Old 07-09-2007, 02:59 AM
  #227
1dirtyZ's Avatar
and where are the pics ???
Old 07-09-2007, 08:56 AM
  #228
WKMCD's Avatar
Slacker...
Old 07-09-2007, 09:06 AM
  #229
7 Second Club
I'll upload them tonight,
Old 07-09-2007, 07:52 PM
  #230
7 Second Club
I did alittle work on the fuel cell/water cell/battery mount, not sure I like it or not yet.
Frame will be welded between frame rails
Fuel/Water cell
Aeromotive Belt driven fuel pump
Aeromotive high volume fuel pressure regulator
Rule 3800gph water pump for IC
Crower solid Lifters
Old 07-10-2007, 05:29 AM
  #231
1dirtyZ's Avatar
why are you using those connected lifters if you don't mind me asking?
Old 07-10-2007, 08:10 AM
  #232
7 Second Club
Everyone I talked to said that they were the best lifters except for the Jesel and my budget doesn't allow for the jesel.
Old 07-12-2007, 08:55 PM
  #233
7 Second Club
Here we go...
  #234
7 Second Club
Thumbs up
Today was tough and long, worked most of the day on my buddies 10 point cage in his talon while he worked on the stang. We got a handful of little projects started and moving in the right direction. Hopefully his car should have one more day of work than I can get this project moving. So far I'm happy and really looking for the final product, should be a completely stupid street car.
Couple shots of the radiator
Exhaust/front mockup
Insanity coming together..
Driver Side Motor:
Passenger Side motor:
Plug access once upper IC pipes is removed, will be on o-ringed v-band clamps
Side shot: Upper intercooler pipe v-band
Front shot: Upper intercooler pipe
3000hp intercooler tucked under dash
Coupe minutes in my dads wood shop to make the beginning of my radiused aluminum turbo inlet hat, using 6" aluminum tubing and some aluminum sheet metal to make the inlet.
Old 07-16-2007, 09:49 AM
  #235
7 Second Club
Threw together the upper IC pipes, they are done except for beading the ends.
Old 07-16-2007, 11:24 AM
  #236
kirtondog23's Avatar
Big Pipes
Old 07-16-2007, 11:53 AM
  #237
WKMCD's Avatar
Very Interesting!!!
Old 07-16-2007, 06:03 PM
  #238
ALL UC2's Avatar
lol, you have a budget??? your makeing me feel bad
by the way, you know your a bad *** when you have not one, but TWO BOV'S!!!!!!!!!!! hell yeah!!!!
Old 07-16-2007, 06:06 PM
  #239
7 Second Club
Yeah, if you saw it you would probably call "BS" on what I paid for most of my stuff. Its really not as high as most would expect. I've gotten deals on almost 100% of the parts I have gotten. My old corvette motor, wheels/tires, nitrous and misc paid for most of the stuff.
Old 07-17-2007, 01:38 PM
  #240
dcorn's Avatar
Phil, this is Dale, Mark Koch's friend. Are those UPR c/c plates steel or aluminum? This probably won't matter to you but I had a set of the steel ones for no less than a day and accidently hit a small curb at speed. It bent the main plate a good half inch out of straight and the c-clip holding in the spherical bearing came dangerously close to popping out. I'm guessing this is because the shock bottomed out, but just giving you a heads up. Maximum motorsports has the best suspension parts out there for mustangs.
So yeah, this build up is completely sick. Your fab skills are nuts. If you have the time, how much would you charge for a simple 4 pt. roll bar in my mustang?
Quick Reply: So here's the game plan 00 Mustang + LSx + huge turbo :)
