LS1 into LT1 Fbody Help
For the fuel system on both cars that I was involved in, I retained the stock LT1 fuel tank and stock LT1 lines. However, I did change the front portion (braided) of the lines and ran the feed into an Aeromotive regulator. The return line came off the regulator since the LS1 rail only has a feed....unless you use the vette rail/regulator (expensive). So, in the end it was much cheaper to buy the Aeromotive regulator and braided line than to buy the LS1 corvette rail/regulator setup that already has the return.
As for the rack....you cannot use the LT1 rack (from my experience) as already mentioned by 765Joey
Thanks
Jason
Get ahold of me on AIM and I'll help you out man.
I am in the process of doing this swap as well. I got everything cheap so it shouldn't be too bad. Almost everything.
If I install a 98 cluster and repin the cluster plug, will my gauges work?
As for the fuel, yes I could use the Vette Rails, but I wanna have a clean show like install, so I am gonna run braided line up, and make a return with an inline fuel regulator.
If you can get a 97-98 Corvette fuel rail, that's a great way to simplify the fuel line hookup! No modifications required at all then. Of course if you are changing to braided line or something else, then it doesn't matter, but if you are trying to do this the easiest way possible, the 97-98 Vette fuel rail is even easier than fitting the Vette fuel filter/regulator assembly to the car.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
also does anyone know the specific wires that go into the lt1 tank?
The LT1 pump will not work for an LS1, LS1's run on 58psi, where LT1's were 43.5psi I believe, so unless you had an inline pump booster. You wont be supplying enough fuel. You can make your LT1 setup work for $500.00 ALL NEW FUEL SYSTEM being braided and all...from the tank up using braided line, and an -AN fittings....
If this is not for you, there have been a few guys contact me with complete fuel setups out of cars, that I could direct to you...
Most of these in-tank pumps are rated anywhere from 90-125 psi deadhead pressure. The fuel pressure regulator determines what pressure the engine actually runs at, not the pump.
On the first LS1 swap we did here (my 91 Z28) we left the stock TPI pump in place and it ran the LS1 at 58 psi just fine. The stock TPI pump carried that car to 11.60's at 116 MPH in the quarter. It wasn't until we supercharged the LS1 that more fuel pump was needed.
The stock LT1 fuel pump will run the LS1 at 58 psi just fine!
www.speartech.com
So take $100 off the price I said of $500 and that's a hell of a price for a braided setup with an Aeromotive Inline regulator
