LS1 into LT1 Fbody Help
Old Feb 28, 2007 | 01:03 AM
  #61
daniel6718's Avatar
so the vette rails fit onto stock lt1 fuel lines?
also, will the ls1 lines clip onto the lt1 tank? i see they have clips on them you pinch to remove, is it the same on the lt1? so if i had a 99 doner car, i could use the tank foroward lines to the engine bay? and the 99 rails?
Old May 23, 2007 | 11:19 PM
  #62
blahster's Avatar
So i just got done with my swap...and can't for the life of me get the fuel gauge to work....
i put a 99 LS1 into my 95 LT1, using stock LT1 dash...are the signals compatible or what would i need to do to get it to work? unless maybe i run the wires from the tank...up to the PCM and wire the fuel level gauge to the output from the pcm...hmmm...will that work? i dunno....
Any feedback?
Also, i read earlier in this post that the tach needs to be setup to run off of 4cyl not 8? i just bought a 3.5" tach to mount on my dash and i set it up as an 8cyl...if i switch the switch to 4cyl then it should work correct?
Also, as far as the water temperature goes, i have an autmeter water temp gauge...can i just splice into the factory sender and get the proper signal or do i need a dedicated sender?
Thanks for the help!
Benny
Old May 24, 2007 | 11:19 AM
  #63
RE AND CHERYL's Avatar
A few have recomended the vette filter as a regulator. Does this filter have a pressure reg built in?? It seems to have one in and two outs on it.
Benny
Did you install the LS1 fuel tank?? If so your kinda screwed because the sending unit on the LS1 tranks is different and won't work with the LT1 fuel gauge.
Re'
Old May 24, 2007 | 11:53 AM
  #64
blahster's Avatar
well that sux...lol. guess there was a reason i got this autometer fuel level gauge then huh....
Old May 24, 2007 | 12:11 PM
  #65
Boosted 99 TA's Avatar
whatd you guys do for a crossmember i had to fabricate the one off of the ls1...does someone make a crossmember for this swap
Old May 24, 2007 | 01:20 PM
  #66
MeanGreenLT1's Avatar
Originally Posted by JasonShort
Sorry it took me so long to reply....I forgot I posted in this thread
For the fuel system on both cars that I was involved in, I retained the stock LT1 fuel tank and stock LT1 lines. However, I did change the front portion (braided) of the lines and ran the feed into an Aeromotive regulator. The return line came off the regulator since the LS1 rail only has a feed....unless you use the vette rail/regulator (expensive). So, in the end it was much cheaper to buy the Aeromotive regulator and braided line than to buy the LS1 corvette rail/regulator setup that already has the return.
As for the rack....you cannot use the LT1 rack (from my experience) as already mentioned by 765Joey
Thanks
Jason
I think i paid about 150 for the 97 vette rail from GM and then 30 for the regulator.
I would just use the vette rail/regelator took me about 15 minutes to install and it worked great.
Old May 24, 2007 | 01:21 PM
  #67
I went from a lt1 m6 to a ls1 a4. None of the cross members from any year would work for the 4l60. I had to fab a little something up to in order to get it to work.
Old May 24, 2007 | 01:23 PM
  #68
You don't have to replace the lines at all. Just use the stock lt1 lines and connect them to the vette rail. The are exactly the same.
Old May 24, 2007 | 01:26 PM
  #69
Originally Posted by XxXTransAmXxX
Just send your harness, and LS1 PCM out to SpearTech and have them rework it, so it's plug and play with the LT1 car, also have them change your tach setup to a 4 cyl signal, instead of an 8 cyl, and your cluster will work.
that was the best investment that I made during the entire project.
Old May 24, 2007 | 01:58 PM
  #70
bjamick's Avatar
So can we get a run down of whats needed for this swap.. I would love to have a 2nd LS1 car ..
So far ive got 99 vette fuel rails and lines..
Send the PCM to john at speartech.
get an LS1 steering linkage.
What about a K member do you jsut use one off an LS1???
Old May 25, 2007 | 05:28 PM
  #71
95GreenZ28's Avatar
So what is the part number for the 97-98 vette fuel rails and regulator?
Thanks guys!! Very informative posting
Old May 26, 2007 | 04:55 PM
  #72
I was always thought that 97 vettes were the only years that had the return line on the rail. I could be wrong but that is the only year that they had it setup like that.
You don't need to have the PCM set out to Speartech. Just get a ls1 comp and anybody that has access to something like HP Tuner can reflash a stock ls1 program in it. You could actually probably just take it to any dealership and get it flashed by a techII. Get yourself a harness and get Speartech to adapt it for you though. They made me a pimp harness that pluged into all the required lt1 connections.
Yes you are going to need to have the ls1 power steering rack because the placement of the knuckle is slightly farther to the drivers side then the lt1 rack.
Old Jun 10, 2007 | 07:05 PM
  #73
95GreenZ28's Avatar
Anyone know these part numbers?
Old Jun 12, 2007 | 09:24 AM
  #74
slowassta's Avatar
for about $150 i did it this way
with an fittings and lines
but i used an LS1 fuel pump assembly, ill try to get pics of it
Old Jun 12, 2007 | 10:27 AM
  #75
95GreenZ28's Avatar
I am wanting to use the 1997 Vette rails and regulator. I think that would be a nice clean install. Anyone have these part numbers available?
Old Jun 12, 2007 | 09:43 PM
  #76
whitehooptie's Avatar
They do not make them anymore. You can not get them unless someone has one laying around. I paid $20 for mine years ago.
Old Jun 13, 2007 | 09:40 AM
  #77
95GreenZ28's Avatar
Yes they do you can get them at GM parts direct. I finally have the part number so if anyone needs them just let me know
Old Jun 13, 2007 | 10:03 AM
  #78
bjamick's Avatar
Ok so how much $$$$ does a swap like this cost? I could have the motor for prob $1500?? How much you guys think im looking at?
Old Jun 13, 2007 | 01:13 PM
  #79
slowassta's Avatar
mine cost me about $5500
$175 longblock
$600 machine work and balancing
$1100 for the heads
$760 for forged h-beam rods and forged pistons
$100 for a 98 gauge cluster
$60 for an LS1 fuel tank and assembly
$200 for 4l60e
$500 yank converter
$25 for 98 a4 harness (and a hacked up 6spd harness)
$100 for 98 PCM
$300 for LS6 intake and P/P Throttlebody
$50 for edelbrock LT's and ypipe
$50 for interior harness
$40 for engine bay Harness
$40 for LS1 k-member
$150 for fuel system (lines, fittings, fuel filter all -6an lines and fittings)
$300 for all gaskets, bolts, timing chain, oil pump
$30 for a fuel rail
$25 for 01 injectors
$150 eibach prokit springs
$100 for LS1 Complete rear and front brakes
$50 for a cam
$120 for rod and main bearings
$50 for an LS1 brake master cylinder
im pretty sure there is other things but i cant remember...altho i didnt have to do all that work for the swap but i figured it would be easier...
Old Jun 13, 2007 | 02:37 PM
  #80
400 vig converter
700 built 4l60
1500 long block
500 Speartech converted LS1 harness
500 Spohn torque arm, lower control arms, panhard bar
250 for the fuel rail and regulator
100 for shifter and deep trans pan
180 for another oil pan since i cracked min
300 for the cam
250 springs, retainers
75 Pushrods
500 for custom h pipe and QTP long tubes
150 plugs and wires
alteast 500 in misc fluids, hoses, gaskets, things of that nature.
250 ASP Pully
130 gmpp pil pump and LS2 timing chain
125 arp head studs
200 new alternator and starter
250 LS7 lifters
500 adjustable QA1's
I really was lucky because alot of my friends had old stock parts that they didn't have a need for and they just gave them to me. Also had some that cut me some really good deals on some used parts.
I think total is about $7000 give or take. I know I probably left some things out. You can do it cheaper and just put all stock parts in but that didn't seem worth it at all to me.
Probably add about another 2500 to that total as well becase i'm sending the motor out to get build a forged 347.
After a while I just stoped counting and kept handing the cash over. It was worth it in the end though cause I could never have found a ls1 car in anywhere as good as shape as my 94 and also been able to have all thoes mods that I have done.
