My 6.0 1971 Olds Cutlass
Old 09-22-2008, 09:41 AM
  #181
ryanvv355's Avatar
No, just vin flash it for the V8 if its an interchangable service # ecm
Old 09-23-2008, 05:30 PM
  #182
ryanvv355's Avatar
I found a handy upper radiator hose today, Dayco 71863.
http://www.mvreader.com/multiview/da...oPart=71863&l=
This will work if using the stock truck upper hose with a 1.5" - 1.25" adapter to adapt the two. I picked one up at Autozone for $13, it is a lower from a 99 Plymouth Voyager 3.3L.
I had a buddy of mine weld a couple -06 fittings on the SPI fuel sender unit.
Old 09-24-2008, 12:31 PM
  #183
A_VAS's Avatar
If you'd like I could email you a tune file for HPT from my 2004 GTO's current setup. Might get you pretty close..and uses the same xxx243 pcm.
I have a MP112, crane cam w/ similar specs as you, 42# injectors, 3:73 gears.....on a 5.7L
You got a few more cubes but might get it running. What size injector you running?
Nice looking swap BTW.....
Old 09-24-2008, 08:41 PM
  #184
seawalkersee's Avatar
???Pardon my stupidity, but I don't understand.???
Chris
Old 09-24-2008, 08:50 PM
  #185
ryanvv355's Avatar
GM used several different service numbers on their ECM's. An 04 S-10 has the same service# as a 03 Express van, or a GTO. The differences are the tunes programed into the ECM. A 4.3 program is currently in my ECM, it needs to be removed and reflashed with an Express van tune to operate my engine.
Old 09-25-2008, 08:15 AM
  #186
Okay, but how do I know if the cumpewter I have is one of them fancy ones that can handle a v-8?
Chris
Old 09-25-2008, 09:12 AM
  #187
ryanvv355's Avatar
cross reference the service # and look for applications listing using that service#
Old 10-04-2008, 07:09 PM
  #188
RacerXLs1's Avatar
how much the motor run you? im lookin to put one in my s10
Old 10-04-2008, 08:23 PM
  #189
ryanvv355's Avatar
$3k, its a 2003 with 38k miles
Old 10-06-2008, 05:40 PM
  #190
ryanvv355's Avatar
I need give credit to Jesse at Wait4me, I mailed him my ecm last Wednesday, I received it today, that's quickness!
Old 10-14-2008, 07:50 PM
  #191
ryanvv355's Avatar
Well we made some serious progress this 3 day weekend. The rear brakes are installed and all the details in the rear are worked out. The Fuddle stall slid in, is all buttoned up and all the wiring is complete on the bottom side of the trans/motor. The air intake is fully installed. The S&P headers are installed, the prop valve had to be relocated inward a bit and some grinding was necessary on the header flanges for a comfortable fit. The ECM is painted, mounted and all of the necessary to run wires are hooked up. I had a battery in and rolled the motor over a few times, I have not finished wiring the DLC so I do not know if the ECM is communicating yet.
Now for the problems, I received the wrong SPI EFI tank. The one I got is a 64-67 unit, I am working with the supplier to get this resolved. The fuel filter is to large to fit anywhere under the car, its going back to Summit and I'll be getting an inline. The 4L80E trans cooler lines hit the floor pan and will not work. I have some fittings on order that should resolve the issue.
I have no pics
Old 10-14-2008, 09:29 PM
  #192
john 67's Avatar
whats your idea to clear the trans lines? i had inline tube bend me a couple of push connect flares with short elbows on 48' pieces - not hooked up yet but i think they will work.JOHN
Old 10-14-2008, 09:40 PM
  #193
ryanvv355's Avatar
I am getting the adapter assembly from Sonnax, basically its an adapter to run th400 lines for an 80e swap. It is pipe thread so i will run 2 tight 90* brass fittings to flare line. This should work.
SONNAX Kit 34918-01k
Old 10-14-2008, 09:56 PM
  #194
john 67's Avatar
im on the same path , the only problem is the brass fitting wont be flare going into the sonnax fitting . and by the time you bend a short 90 on a piece of tubing you are basically in the same place you started out from.I hope you work it out , so i can copy you. sonnax should make that fitting in a 90 degree version, there is a need for it --there is a thread on this within 2 pages or so about this as well. JOHN
Old 10-14-2008, 09:58 PM
  #195
john 67's Avatar
did you do your exhaust yet?what are you planning?
Old 10-14-2008, 09:59 PM
  #196
ryanvv355's Avatar
I'll braze something up then, this little hiccup isn't keeping me from firing this pig off
i'll beat the **** out of the floor if i have too.
exhaust will be 2.5", Jeg's x-pipe with e-cutouts before the x, then on to Aero-chambers, then over the axle and out back, the cut outs will get dumped.
Old 10-16-2008, 06:18 PM
  #197
ryanvv355's Avatar
Here are a few pics from this weekend, nothing much topside. The plug wires are on, AEM Dryflow filter installed and braced, PCM and fuse block installed, battery cables ran, vacuum lines routed
Old 10-16-2008, 08:41 PM
  #198
loweredd's Avatar
Lookin' good doooood.
Old 11-07-2008, 06:04 PM
  #199
ryanvv355's Avatar
I spliced my hoses together with some hardware store plumbing pieces. I used a 1.25" to 1.5" hose splice and 2 pieces of brass plumbing pipe inside the 2 radiator hoses, so the clamps on the splice would have something to clamp against. Cost = $10
Old 11-08-2008, 12:48 AM
  #200
luckyhenriksen's Avatar
Looks badass. is this gonna be alrght?
Quick Reply: My 6.0 1971 Olds Cutlass
