been lurking, my LS1 drift car (240sx)
I've been on ls1tech for a while as a lurker really, so here's my too-long introduction.
Decided to go LS1 after breaking 7 transmissions last season with my 2.4l turbocharged nissan setup making around 4-450hp, engine was totally reliable, I just didn't want to spend $4500 on a reliable gearbox
the old setup:
video:
http://www.youtube.com/watch?v=tdprxGUEG1U
![](http://mattmartindrift.com/albums/rebuild/sema7.jpg)
enough with the old, in with the new:
here are the specs on the new build
2000 LS1 from a camaro w/ 15k miles on it will be turned to 7,000rpms and run on E85 Ethanol/gasoline fuel.
- Typhoon Intake manifold
- 90mm Q45 Throttle Body (screw paying $400 for a GM "bolt on" 90mm throttle body, i'll stick to good ol' junkyard $40 TB)
- PRC dual valve springs + titanium retainers
- Comp Cams camshaft w/ specs somewhere in this area: 232/232 w/ .598"/.598" lift
- Comp Cams 7.400" hardened pushrods
- Harland sharp rocker arms
- ARP rod bolts
- ported LS6 oil pump
- LS2 timing set
- Electromotive TecGT engine management
- Billet anodized fuel rails -8 feed, -6 return
- GM 42# fuel injectors
- Walbro 255lph pump
- Custom (yet to be) made by me long-tube headers
- 18"x30"x4" C&R/Visteon Ex Nascar Nextel cup counter-flow radiator + oil to water heat exchanger (had to cut the frame rails)
- 1L custom surge tank, -4 feeds, -10 return
- GTO oil pan + pickup
- notched front X-member
- T56 Transmission (still need to buy) w/ TBD clutch/flywheel
all said and done: i'm hoping for around the 400whp level on our dyno dynamics dyno. However the main point to this whole swap was to have close to equivalent HP to my old KA-T setup while having a reliable transmission!
I still need to buy the Cam, pushrods, transmission, and a couple other things, so ANYONE that could help me source an LS1 T56 I'd really appreciate any help.
I don't like where the engine is sitting, so I might go back and re-notch the X-member, and possible push the motor up an inch or so and see how much further I can massage it back
anyways!!! pictures
Front view
![](http://mattmartindrift.com/albums/ls1/DSCF1183-sm.jpg)
![](http://mattmartindrift.com/albums/ls1/DSCF1174-sm.jpg)
![](http://mattmartindrift.com/albums/ls1/DSCF1202-sm.jpg)
![](http://mattmartindrift.com/albums/ls1/DSCF1175-sm.jpg)
![](http://mattmartindrift.com/albums/ls1/DSCF1176-sm.jpg)
Q45 throttle body
![](http://mattmartindrift.com/albums/ls1/DSCF1177-sm.jpg)
thermo housing + -10 surge tank return
![](http://mattmartindrift.com/albums/ls1/DSCF1182-sm.jpg)
-20 upper rad hose and -10 surge tank return + frame notch
![](http://mattmartindrift.com/albums/ls1/DSCF1184-sm.jpg)
Passenger side notched frame rail
![](http://mattmartindrift.com/albums/ls1/DSCF1185-sm.jpg)
Passenger side notched frame rail........again
![](http://mattmartindrift.com/albums/ls1/DSCF1186-sm.jpg)
Oil to water heat exchanger (driver side)
![](http://mattmartindrift.com/albums/ls1/DSCF1188-sm.jpg)
driver's side frame notch
![](http://mattmartindrift.com/albums/ls1/DSCF1189-sm.jpg)
Driver's side motor mount:
![](http://mattmartindrift.com/albums/ls1/DSCF1190-sm.jpg)
Driver's mount again
the old setup:
video:
- ARP rod bolts
- LS2 timing set
anyways!!! pictures
Front view
Q45 throttle body
![](http://mattmartindrift.com/albums/ls1/DSCF1191-sm.jpg)
Passenger-side mount
![](http://mattmartindrift.com/albums/ls1/DSCF1193-sm.jpg)
surge tank
![](http://mattmartindrift.com/albums/ls1/DSCF1194-sm.jpg)
Too much room in the back because I notched the X-member as much as possible, but that's what's left....
GTO oil pan to X-member clearance.
![](http://mattmartindrift.com/albums/ls1/DSCF1196-sm.jpg)
Passenger side top view
![](http://mattmartindrift.com/albums/ls1/DSCF1197-sm.jpg)
passenger crank case -6AN vent
![](http://mattmartindrift.com/albums/ls1/DSCF1198-sm.jpg)
driver crank case -10 vent
![](http://mattmartindrift.com/albums/ls1/DSCF1201-sm.jpg)
Big Muthaf'n radiator
surge tank
![](http://mattmartindrift.com/albums/ls1/DSCF1203-sm.jpg)
Looking good so far, I see you are using solid engine mounts.
Let us know how that Q45 TB works out. I am using one on my RB motor that I am swapping for an LS1. I have an extra one I could use, but I am not sure how the ECU will handle the TPS and IAC.
Originally Posted by Meierznutz
Very nice set up. Keep up the good work... Chris
yeah, i'm running full stand alone, so i'm not worried. However, nissan TPS is a nice steady 0-4v sweep. I don't imagine it could really be that different unless GM is full 0-5v. The ECU I use is calibrated/built to GM sensor standards, and the only parameters I can change is WOT voltage and close voltage, usually a 0-5v sweep. I don't run an idle valve, so mine is usually like 0.49-4.00v as I prop the TB open a hair. It just liked to stall the 4 cyl. when it was cold, then idle would be great when it was warm.
However, the Q45 TB has a coolant passage which has a temperature controlled diaphragm that will bump up the idle when cold, and bring it down when hot by adjusting the throttle stop.
The throttle linkage is also on the other side if that makes a difference. You also cannot use a plastic intake manifold because you have to drill/tap and do a little finessing.
Last but not least, you'd need to fabricate some sort of idle control that does not run through/ in conjunction w/ the LS throttle body (i was told LS1 works this way, never actually looked closely at one of the GM throttle bodies)
I see you're in westminster; I'm based out of ma-motorsports in baltimore.
nice car, great swap....but damn those stars are gay. Sorry guess we all just have diffrent taste. I think you will find that the ls1's have a TON more usable power than that KA. Good luck and keep us updated.
Originally Posted by njn63
Is that the same car that was banged up at Formula D in Chicago in 2005? The paint job looks familiar.
sure is!
crash and rebuild photos
We shall see. I really loved how useable the KA power was compared to the SRs that most swap.
My KA was full boost by 3200 RPMs w/ a GT3076R turbo revving to 7k w/ a 7.5" twin plate clutch and tons of other goodies, so it revved, it was responsive, and made fairly linear power delivery that had no problems breaking 265/35/18 rear tires loose in 4th gear.
p.s. I'm cool w/ gay looking. I'm artsy/hippy at heart.
Originally Posted by mattmartindrift
Good luck with the ls1.
I don't like where the engine is sitting, so I might go back and re-notch the X-member, and possible push the motor up an inch or so and see how much further I can massage it back.
mmdb's
![](http://i7.photobucket.com/albums/y259/mmdb/LS1%20Swap/img008.jpg)
icantdrift's
![](https://img226.imageshack.us/img226/8887/vetteox8.jpg)
fouz65's
![](http://www.damagefxclan.com/InvisionBoard/uploads/post-3-1158622204.jpg)
![](http://www.damagefxclan.com/InvisionBoard/uploads/post-3-1158622345.jpg)
others...
slo240sx
mikespeed
datboibrad
and probably more
radiator looks sweet along with the intake
will be nice to see the custom headers
Hey Matt, looks good! Its funny you posted up, Fedor came into my shop today (Tuning factory) and mentioned you sending him pics of your setup. He had nothing but good things to say and I can see why ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Give me a holler if you need any help.
-Alex
![](http://img80.imageshack.us/img80/4300/dscn03366sj.jpg)
-Alex
![](http://boner.berettaspeed.com/ChicagoDrift/000_0444.jpg)
This the same car as above? It looks like it from the Soldier Field drift event a couple years ago, if so did you sell that messed up from bumper to some guy? I thought I saw someone walking around with it.
yes, and yes, i sold pretty much all the broken stuff
Originally Posted by TrAb
Very nice car, What fuel pump are you going to use?
