6.0 into a '82-'93 S10: Which oil pan?
Old 05-09-2007, 03:59 PM
94snake's Avatar
Default 6.0 into a '82-'93 S10: Which oil pan?
Ive been searching on here but I just can't seem to find a clear answer to this. My friend is putting a 6.0 into his '82 2WD S10 and he has everything to do the swap except a pan. Can anyone tell me which one he should use for this?
Thanks!!
Old 05-09-2007, 04:31 PM
jay_lt4's Avatar
stock 6.0L pan on mine, just cut and box the frame section about 8" x 2"
Old 05-09-2007, 04:51 PM
94snake's Avatar
I noticed your's is a '99; are they the same as the earlier models?
Old 05-09-2007, 06:37 PM
Ls2Sonoma's Avatar
frame is very similar
cut that amount and test fit before welding. i had to cut more, but i mounted the engine lower
Old 05-09-2007, 07:00 PM
1999ssls1's Avatar
Ive got a pan if you need one
Old 05-10-2007, 12:34 AM
dotstereo's Avatar
I've always wondered: when you guys notch pans, what do you do about the lost oil capacity?
94Snake, is that you from Supraforums?
Old 05-10-2007, 07:29 AM
94snake's Avatar
^Yep its me
Old 05-10-2007, 07:34 AM
94snake's Avatar
Well since my friends is an '82 and not a '99, can anyone tell me for SURE what will work?
Old 05-10-2007, 08:37 PM
Unaffliated Racing's Avatar
yes it will work...I have the stock unmolested 6.0 pan in my 91 frame
Old 05-11-2007, 03:00 AM
Ls2Sonoma's Avatar
you simply dont put in as much oil...
but i know what you mean. losing a quart of oil wont hurt anything.
lets say you were to do a high volume/capacity oil pump - when youre into the high rpm, the pump can evacuate all the oil in the sump and the oil cannot return to the pan fast enough. a solution would be not running such high oil pressure if possible. most street/mild track driven engines dont need high volume pumps
Old 05-11-2007, 12:16 PM
94snake's Avatar
Thanks man, thats what I needed to know!
Quick Reply: 6.0 into a '82-'93 S10: Which oil pan?
