BUILT LSX Stroker into a 95 Z28
Old 08-04-2008, 02:25 PM
  #121
the_merv's Avatar
The Tubular K-Member will work fine. The T56 Cross Member and the Mount can be used. To be honest with ya.. the easiest way to swap to LSX is to use LSX stuff. I'm in the process of swapping this setup over to a T56 at the current moment..eveything is going smooth.
For the T56 you can get a LS1 T56 Front Cover and Imput Shaft.. that will work the best.
Look for someone that has a LS1 T56 and wants to put it behind a Gen I Engine and see if they want to trade the Front Cover and the Imput Shaft for yours..
You will need a LS1 Bell Housing as well..
Old 08-05-2008, 06:17 AM
  #122
Tim_in_NC's Avatar
Thanks Merv!
Old 08-13-2008, 09:06 AM
  #123
the_merv's Avatar
Here is the thread to my T56 Swap:
T56 SWAP
Old 11-15-2008, 03:51 AM
  #124
ROUDA's Avatar
this is a awsome thread.
Old 11-17-2008, 06:08 PM
  #125
Chased's Avatar
Originally Posted by daniel6718
thats kool..well my fake power gets me about 625 at the wheels...so thats nice...i guess if i had of dumped about 8 grand into my car i coulda have 600 on motor and 900 on spray or so...o well...my 625 is enough to get me into the 9's thats all that matters...
got any vids of blowing the tires off at 70+ mph?
i have vids of me blowing the tires off with m/t d/r at 55mph
OWNED sorry dude I agree 80% of NHRA cars are spray cars till them guys it fake power
Old 11-17-2008, 06:59 PM
  #126
TheBiz's Avatar
Can't believe this thread is still going. The swap isn't bad at all. Just get your ducks in a row PRIOR to starting the swap.
I just changed the motor in my TA again.
Old 11-17-2008, 08:58 PM
  #127
the_merv's Avatar
I have plenty of friends that do it too with some big cars.. they don't give me **** about it cause they know that I don't. We had that conversation a long time ago between me and him and he was claiming his power with N20 and I was claiming mine without it, kinda like apples vs. oranges IMO..
Old 11-18-2008, 05:14 AM
  #128
95 bright teal's Avatar
Nice build, Its been a while since ive read your threads last time was when you were making a lid fit under your stock hood and no one said you could do it and look at you now an lq4!
Congrats and have fun! your making me wish i kept my z28
Old 12-28-2008, 06:15 AM
  #129
LS1HIGHLIFE's Avatar
Very nice build. Looks like a lot of great time effort was put into this. Congrats. BTW was that the auto hobby shop you pics were in? AF right?
Old 12-28-2008, 06:23 AM
  #130
the_merv's Avatar
Yea, I installed it in the Auto Hobby Shop.
I started it there with open Headers and rattled the place..lol
Old 12-28-2008, 06:29 AM
  #131
Nice, Andrews AFB here. Currently deployed to the IZ right now. You must deploy quite a bit to afford those nice toys.....lol
Old 12-28-2008, 06:56 AM
  #132
the_merv's Avatar
Not really, just a single E5 at the time. I'm currently deployed now, but I've got other things to do now with the money, family comes first.
Old 12-31-2008, 11:36 PM
  #133
mr1newyork's Avatar
funny to run into your story, i've been planning to do the same nearly exact thing your doing. i finally bought a LQ4 from a '01 3500 series and getting ready to put it in my nine 4 T/A. so i know mines is going to work. i'm seeking 500+ H/P w/no special mods. it can be done. A DAILY DRIVER. still reseaching. look out vettes.
Old 01-01-2009, 12:51 AM
  #134
mr1newyork's Avatar
o.k. how 'bout ls2 valves on a lt1 heads. is it possible? i think edelbrock's doing it!
o.k. ls throttle bodies on lt's manifold's! with a little cutting and welding. they did it for the super rams! ANY PRO'S OUT THERE?
Old 01-07-2009, 02:34 AM
  #135
t_raven's Avatar
Just read your thread merv, considering how many so called "mechanics" I've worked with here in Iraq that wouldn't have the first clue about modifying the harness, you'd definitely put most of them to shame lol.
Old 01-09-2009, 04:53 AM
  #136
panzer1320's Avatar
Default doing the a similar swap in a 93'
I have followed this thread for a while and I am very impressed! I have a 93 TA that i have owned for about 18 months and has sat in my garage. I am about to buy a k-member and steering knuckle/linkage from an ls1 f-body. I was planning on useing the lq-4 and speartech computer that I bought from another member of this site. My question is can i use the stock trans from the 93 car? This is my first serious motor swap and I thought that my trans from the 93 was identical to a 700r-4. Upon further reading I have found that it may not be. I have confused myself and would like to clear this up. Will I be able to run the stock trans or will I have to do a th-400/350 swap to avoid further changing my pcm? I will not take offense to any newb comments at my expense as I feel that I am not eduated and they would help me finish my swap in the fastest manner possible. Any help is appreciated
Old 01-09-2009, 05:51 AM
  #137
the_merv's Avatar
You can use your Stock Trans, but you are going to need a Crank Spacer for it. You would have to do the same for the TH350 or TH400 aswell.
Old 01-09-2009, 07:02 AM
  #138
panzer1320's Avatar
K so all I will need is the spacer and converter for my app. I am going to a local tranny shop for this as I fell this is the best option. Thank you for the advice!
Old 01-09-2009, 07:14 AM
  #139
t_raven's Avatar
The stock 6.0s had a crank space when used with the 4l80e. Does your lq4 still have the flexplate and spacer? I'm not sure, but the bolt holes for the torque converter on the 4l60 maybe be slightly off if using a 6.0 flex plate. you can get a different flex plate of just oblong the holes a little.
I was looking into replacing the 4l60e with a 4l80e in my 5.3l silverado. I would need a crank spacer and the torque converter holes would be slightly off. So I'm guessing they would be off in the opposite direction if using a 6.0 and 4l80e flex plate and a 4l60 transmission.
Old 01-09-2009, 08:20 AM
  #140
the_merv's Avatar
Some of the 4.8l's had the longer Crank Flange from what I have read too, they had a 4L60E, more than likely the older style. I wonder if that Flex Plate would work.
Quick Reply: BUILT LSX Stroker into a 95 Z28
