name that harness [help needed]
in the mean time also...so if anyone knoes wat/where each plug should go plz advise me of so...or lead me to where i can find the info...appreciate anyone's help....these two are on one group of flex tube...
is this one with the blue rubber for o2?? don't have o2 in my hand so can't vfy...
does this one go into the 6sp tranny??? i have the tranny off so i can't vfy...
these are closer to the red/blue plug to pcm
there's quite a few of these o2 plugs....anyone know how i can tell which one is which??? i'm trying to avoid from opening up the flex tube and tracing it back...i check the faq and only see the wiring output from the red/blue connector...not the individual plugs themselves...
AC Connector
Driver side Coil
Alternator and Temperature
Air Temp
Knock sensor
MAF, TPS and IAC
Oil Pressure (you don't need this one)
Pass Coil
Hope that helps....
AC Connector
Driver side Coil
Air Temp
Knock sensor
MAF, TPS and IAC
Pass Coil
Hope that helps....
Oh, does your second pic in the first post have grn/brn wires? If so, that is your backup lamp switch on the pass side of the trans.
yeah...it's green and something dark...either brown or black...
and the 3rd pix from first post that no one doesn't seem to knoe wat it is yet ish in a bundle very close to the blue/red connector...here's hopefully a better pix...
these two plugs here appears to be an interior plug...becuz they are on a pigtail and has a rubber gromet in the middle of the pigtail....maybe this may help someone on here identifying this for me...
ls1 M6- http://www.hotrodlane.cc/Instruction.../InstalT56.pdf
ls1 A4- http://www.hotrodlane.cc/PDFFILES/ls...icharness2.pdf
1. 02 SENSOR
2. HARNESS TO CAR UNDERNEATH THE GLOVE BOX
3. TPS CONNECTOR
4. PASSENGER SIDE WHEEL WELL.
Should be another one there also..and a 10g Purple Wire with a Plug.
5. GRAY ON IN THE BACK-MAP SENSOR
BLACK ONE- CRANK POSITION SENSOR
i found a similar pdf from s&p while searching....not that one in particular....thanx...also while searching i found out the name of those two plugs are c220 and c230...
3. TPS CONNECTOR
The ones on the Wheel Well are named C-100(10 pin black), C-101(10 pin gray), and C-105(8 pin black).
by any chance u knoe or have documentation to the function/pin-layout of these connectors???
wat do u mean??? where else would it go in the car other then the ignition switch???? i guess it would be custom since it's a hybrid...
