The G-Body Swap Thread
Old Jul 25, 2012 | 06:48 PM
  #861
5.3 cutty's Avatar
Originally Posted by BOXCHEV
Some people just mount it on the wheel wheel under the hood like factory. Personally don't like the look. Matter of fact I don't even want to see the PCM. Yet still want it easily accessible. I'm going to either relocate the horns that are mounted inside the driver side fender to the passenger side and place pcm there where the horns used to be then make a cover to hide it, or I'm going to mount it inside the car behind the dash somewhere. Might be building a center console from scratch so directly under the dash where the radio is could be an option hidden inside the console.
same here i never thought about ware the horns are ..gona check that spot out tomorrow. thanks fellas
Old Jul 30, 2012 | 11:20 PM
  #862
86Regal_Pearl's Avatar
What size is the fuel inlet going into the fuel line at the back of the engine.
there are 2 inlets, 1 appears to be larger than the other. What size are these?
Old Jul 30, 2012 | 11:39 PM
  #863
Emdmechanic's Avatar
3/8 inlet and 5/16 fuel rail return.
Old Jul 31, 2012 | 01:13 PM
  #864
This is on top of the L31 engine? Going towards the firewall?
Old Aug 12, 2012 | 09:06 AM
  #865
tta656's Avatar
bump as g bodies rock
Old Aug 12, 2012 | 09:31 AM
  #866
Silver T's Avatar
https://ls1tech.com/forums/forced-in...ders-pics.html
My thread of what I got so far
Old Aug 12, 2012 | 11:50 AM
  #867
tta656's Avatar
Kevin i am Bandaid on TB.com ....still waiting for you to get Tom to make me a set....
Old Aug 12, 2012 | 02:10 PM
  #868
BOXCHEV's Avatar
Those that have 1in setback plates and 4l60e what trans dipstick are you using?
Truck dip stick, car, aftermarket?
Old Aug 12, 2012 | 02:35 PM
  #869
tta656's Avatar
think i read alot use the lokar
Old Aug 12, 2012 | 03:23 PM
  #870
pmgm's Avatar
I need a dipstick too.. I wonder if the car one will fit.. Almost bought the lokar when I was at Summit but I wanted to see if a factory one would fit first..
Thanks
Old Aug 12, 2012 | 03:46 PM
  #871
BOXCHEV's Avatar
x2 I would like to use a factory one as well.
Old Aug 18, 2012 | 11:06 AM
  #872
Storm53's Avatar
Default column shift
Is anyone running a column shift in there g-body? I have an 81 malibu and I want to retain the factory column shift when I complete the ls1/4l60e swap. I would like to run a set of headers instead of the factory manifolds, but I don't want to have to beat up the primaries or collectors. Is there a header that actually fits properly? Would I have to modify the linkage if I just go with the manifolds?
Old Aug 18, 2012 | 03:11 PM
  #873
lt4malibu's Avatar
You have to modify the linkage when using the BRP headers if you want to be able to shift manually into first gear - the lowest you can go is second befor the lever hits the header
Old Aug 18, 2012 | 03:16 PM
  #874
Storm53's Avatar
You wouldn't, by any chance, have pictures of the modification? BRP headers fit otherwise? I really don't want to have to dent any of the tubes. Would I have to modify the linkage if I went with manifolds?
Old Aug 18, 2012 | 05:39 PM
  #875
Heavy foot's Avatar
I've seen this set up using a cable set up with the column shifter.... Post #134 http://www.s10forum.com/forum/f10/1s...75/index3.html
Old Aug 18, 2012 | 08:55 PM
  #876
pmgm's Avatar
What lower hose are you guys running with a g body radiator?
Thanks
Old Aug 19, 2012 | 10:29 PM
  #877
What do I do w/ my speedo cable on the 4L60E?!
Also, I'm looking at buying a Dakota Digital Dash for my Regal... how would that work as far as sending and receiving info to and from the engine sensors and trans?
Old Aug 20, 2012 | 12:59 PM
  #878
2Aspire's Avatar
Thanks
I was able to tweak the one that came with my 4L65E from an 06 GTO by hand and it fits perfect.
I am but mocked up and purchased custom headers to work around it from these guys..
http://www.stainlessheaders.com/index.aspx
Below are the finsihed headers and a shot of how far they hang down to clear.
Old Aug 20, 2012 | 01:16 PM
  #879
BOXCHEV's Avatar
Those headers are nice, did they duplicate the bends needed to make more upon request? Would be good for them(sales) and other gbody people that want to keep column shifter.
Old Aug 20, 2012 | 04:18 PM
  #880
2Aspire's Avatar
Once they made mine they literally broke the mold. They are made per the mock-up kit they give
Unless you request your mock-up back they disassemble it and keep the reusable parts.
I Used John Bs mounts though so that may not necessarily be an issue if you want to go custom as your motor placement and areas to clearance will vary from mine unless you have the same mounts.
