The G-Body Swap Thread
Old 12-09-2013, 12:32 PM
  #1041
HeadGames Dave's Avatar
NEED V8 Frame mounts!!
Swapping into my T-Type and the V6 mount won't work with alot of mods
Old 12-09-2013, 12:50 PM
  #1042
streetknight2's Avatar
I'm in same boat... let me know what you find
Old 12-09-2013, 01:11 PM
  #1043
85-6.0-REGAL's Avatar
I was told to get the Monte SS frame mounts from Autozone. That's what I have now for my 85 GN just haven't put them on yet
Old 12-09-2013, 03:35 PM
  #1044
BOXCHEV's Avatar
Could get some from junk yard easily, or make wanted add on gbodyforum. Someone probably has some laying around.
Old 12-09-2013, 05:06 PM
  #1045
Do you have part # on them?
Junk Yard's out of the ? on this stuff around here. It all got crushed a couple years back
Old 12-09-2013, 05:13 PM
  #1046
yeah, calling there is usually like calling the twilight zone. Much easier to get a part number lol
Old 12-09-2013, 05:19 PM
  #1047
just checked the website, and they only have the engine side
Old 12-09-2013, 06:11 PM
  #1048
Docked Wage's Avatar
I'm getting ready to do my T-Type also.
I thought I read somewhere that you could reuse the V6 mounts by moving them forward and flipping them.
I think it required drilling some new holes in the crossmember.
Supposedly once you do that all that is needed is a set of LS adapter plates.
If I'm way off here I apologize. Please keep flaming to a minimum.
Ken
Old 12-09-2013, 06:17 PM
  #1049
that's what my builder told me today. He just flipped them. Thought $17 was WAY WAY cheaper and easier. But, what do I know.
Here is what I found for the Autozone mount
http://www.autozone.com/autozone/par...artNumber=true
Old 12-09-2013, 06:28 PM
  #1050
Mt.Dew's Avatar
Just put out a wanted add for mounts on MonteCarloSS.com and MalibuRacing.com. I picked up a set. But SEVERAL people replied. Head over there guys, 1 guy had 3 sets.
They are going for $20 plus the ride.
Good Luck.
Old 12-10-2013, 08:37 AM
  #1051
spacemanspif's Avatar
Pretty sure I got my NEW frame mounts at NAPA for around $20.
Just looked; p/n is BK 6021179 and they cost $8.70 each.
Old 12-10-2013, 01:31 PM
  #1052
BOXCHEV's Avatar
Original mounts >>> parts store china reproductions
Old 12-10-2013, 01:35 PM
  #1053
BOXCHEV's Avatar
Also you don't have to get ones from a gbody, a lot of other 80's gm cars use same mounts for v8's
Old 12-10-2013, 02:55 PM
  #1054
That's the ones I got! You are just going to have to find the clam shell ones for the engine to bolt on your adapter plates
Old 12-11-2013, 10:41 PM
  #1055
6togo's Avatar
Getting ready to pick up a new radiator for the GN build they have rad's with inlet/outlet on the same side and opp. sides which is easier to work with when you have a LS?
Old 12-12-2013, 06:50 AM
  #1056
Getting a radiator with inlet/outlet both on the passenger side will allow you to use the shortest hoses possible. If having it made, have them add a fitting for the steam line too.
Old 12-12-2013, 06:53 AM
  #1057
I was thinking of using the Dirty Dingo Sliders. Anybody know if these mate with the stock mounts?
Since I'm using the truck intake with a DBC throttle, I'm concerned that if I have the clam shells and the adapter plate stacked that I may run into clearance issues with the hood. Using these will give me back a 1/4 inch or more depending on the angles.
Old 12-12-2013, 10:22 PM
  #1058
BOXCHEV's Avatar
Originally Posted by BOXCHEV
Anyone using factory floor shifter with 4l60e?
Trying to get the monte floor shifter that was used with 200r4 to work with my 4l60e, using 1in set back plates.
I sold the old 305 and trans a while back, didnt even cross my mind to take the brackets off the original trans if that's all I need for the shifter to work with the 4l60e.
Bought B&M cable.
Looks like I can get it to work with threaded rod and few nuts and washers.
RED- rod
Blue- nuts
Old 12-13-2013, 09:14 AM
  #1059
Good idea Box, I am not even close to that stage yet but I am also going to have to figure out how I will make my floor shifter in the GN work my 4L80e
Old 12-15-2013, 02:58 PM
  #1060
xsivpwr's Avatar
Spohn has them and other conversion items
Quick Reply: The G-Body Swap Thread
