Wiring OBD-II using GM pinouts or using Nissan/import pinouts? emission questions
It looks like gm and Nissan uses different pin outs for their obd-II connections. My main concern is the serial data link pin out. I'm just wrapping up my car and just thought if it even matters which pin out system you use. all i know is their tool checks weather there are any codes present and all systems are ready and also their is no MIL light on.
My question is if the emissions tools they use just try to seach the 3 different styles of obd-2 and see weather it can connect.
I've wired the MIL light on
My engine supplier turned off
REAR 02
EGR
AIR PUMP
VATS
My ls1 is from a 2001 ws6 and I put it in my 1998 240sx.
REAR 02
EGR
AIR PUMP
VATS
You will want to wire it for the GM. If remember correctly the Nissan connector should have the serial link AND some additional wires for their propriatary Computer interface. The name escapes me at the moment.
Most code readers can try the the 3 different communication types. Mine does anyway.
REAR 02
EGR
AIR PUMP
VATS
REAR 02
EGR
AIR PUMP
VATS
Originally Posted by Thaniel
Yah Consult that's it. My nissan engine is a 2000. It has the consult and OBDII in the same plug.
damn...small world...or small internet world...i remember reading bout ur rx7 years ago on maxima.org....
just repin the nissan connector to the GM spec. you MUST do this. they use different forms of data transfer.
its very easy to do, i literally just did it 5 minutes ago to my OBD2 plug haha
on the top of the connector there is a little whire flap, pry it open gently with a small screwdriver. then from the front with the same small screw driver (really small here) lift up the locking tab on the wire. it will slide right out from the back.
move it to pin 2, it will snap into place, then close the flap on the top.
