What is the best way to hook up a th350
Old Aug 6, 2007 | 08:24 PM
burns_auto's Avatar
Default What is the best way to hook up a th350
looking for some info, do i need a spacer or a whole different flywheel... part numbers and prices and where to buy would be great to know...
thanks
bjb
Old Aug 6, 2007 | 08:28 PM
classic gary's Avatar
scoggin-dickey in texas.
Old Aug 6, 2007 | 08:49 PM
G-Body's Avatar
sawzall wielding director
You will need a spacer, flywheel and different bolts. The spacer bolts between the crank and the flywheel (hence the need for longer bolts) and you need a new flywheel to restore the alignment between the ring gear and the starter. Let me see if I can dig up those PN`s.
Old Aug 6, 2007 | 09:05 PM
PRAY HRD's Avatar
i thought all you needed was to get a converter with the correct hub/snout for an ls1 when ordering? can anyone confirm this?
i personally know a guy running an ls1 with a th400 and he's not using a spacer/adapter of any kind. he just had to order his converter to be used with an ls1 and that was it.
i don't know what he did for a flexplate, but TCI makes a stronger than factory one that most guys are using with their th350/400 swaps.
Old Aug 6, 2007 | 09:14 PM
G-Body's Avatar
Yep, if you are getting a new convertor most TQ convertor companies can make one that will bolt right up. You just have to let them know that you want a LS1 nose on the convertor.
Old Aug 6, 2007 | 09:39 PM
G-Body's Avatar
The PN`s are in this thread https://ls1tech.com/forums/conversions-swaps/471293-yet-another-crank-spacer-question.html . the flywheel and spacer are in post 1 and the bolt pn is in space 6.
Old Aug 6, 2007 | 10:36 PM
burns_auto's Avatar
thanks for all the info... can't wait to hear this thing run..
Old Aug 9, 2007 | 07:13 PM
chevydad's Avatar
is that the same spacer that's on the lq4's? mine had one on it when we pulled it.
Old Aug 9, 2007 | 09:49 PM
G-Body's Avatar
Yep thats the spacer, its used on the 6.0L motors so that they will bolt to the 4l80e (the 80e still has the same torque convertor spacing as the old th350, th400, 200r4, etc)
Old Aug 9, 2007 | 11:58 PM
ryanvv355's Avatar
so your saying a 400 trans and converter will bolt up to an LQ4?
Old Aug 10, 2007 | 06:13 AM
nobreaks254's Avatar
I have a flexplate with spacer and longer bolts if anyone needs them. PM me.
Old Aug 10, 2007 | 08:32 AM
G-Body's Avatar
The motor will bolt right to the trans, and the spacer extends the crank so that it will be the right depth for the convertor nose. I believe that the spacing for the 3 bolts that bolt the convertor to the flexplate is the same, but I cannot guarantee that yet as I have not physically checked it. In another post I read that you need a 1998 flywheel and that the 1999 and later have a 2mm smaller diameter bolt circle. That does not make sense to me because I bolted a 4l60e from a 1998 camaro to a flywheel for a 2001 tahoe. I have a 6.0L flywheel and spacer sitting so i could give you the dimensions if you want, but all my th350`s and 400`s are buried in the back of the garage so I have not tried to actually bolt one up.
Old Aug 10, 2007 | 08:55 PM
chevydad's Avatar
i know my th350 convertor won't bolt up to a 6.0 flexplate, i checked. i may just try to redrill it.
Old Aug 10, 2007 | 09:00 PM
ryanvv355's Avatar
No biggie, I'm just curious thats all. Im sticking with my 4L80 for now. That info would be put towards another project down the road.
Old Aug 14, 2007 | 09:08 AM
brando1985's Avatar
http://www.speedwaymotors.com/p/6767...tml?itemNo=ls1
Old Aug 14, 2007 | 12:21 PM
jay_lt4's Avatar
$200 is a lot for something that isnt needed.
https://ls1tech.com/forums/automatic-transmission/639693-ls1-style-engines-old-style-trans-th350-400-2004r-700r4-4l60e.html
Old Aug 15, 2007 | 03:12 PM
Darracq's Avatar
I just opened the holes up a little on my flexplate, works fine.
Old Aug 16, 2007 | 12:05 AM
GraphicNature's Avatar
i put a tci flexplate on my ls1 an kenny at ptc build me a convertor they bolted up with no spacer needed
